All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-03-2013, 09:20 PM
vinny8765 vinny8765 is offline
Junior Member
Default Black and Decker 1.7Cu-Ft Mini Fridge
Model # BNA17B
115V 60Hz
1.6A
130W
Motherboard?: PCB90425K2
The problem I have with this is fridge is that it gets my room way too hot. It uses dual Peltier thermal-electric cooling modules for it's primary source of cooling. It works but it's not very efficient as we all know. I was wondering if I could swap out the 90mm fans for something else such as a delta fan, but my concern is that the stock fans are operating at 12v .16A and a delta fan would draw much more amps than that. So would it be alright if I switched the stock fans to one of these? And if any, what modifications would I have to do? I would also like to be able to just replace that board with a PSU from a computer.
http://www.newegg.com/Product/Produc...82E16835132021
http://www.newegg.com/Product/Produc...82E16835705013
  #2
Old 07-03-2013, 11:32 PM
blueroomelectronics's Avatar
blueroomelectronics blueroomelectronics is offline
Default
You need to keep those Peltiers cool or they lose their efficiency and could also be damaged from overheating.
Remember you don't make cold, you remove heat.
__________________
Bill
  #3
Old 07-04-2013, 12:26 AM
Junior Member
Default
Yeah I gotcha:P But my main objective is to remove and dissipate the heat with better fans(higher rpms and higher cfm) but since they draw more power, I was wondering if it was okay if I added fans with higher amperage requirements.
  #4
Old 07-04-2013, 12:47 AM
#12's Avatar
#12 #12 is offline
Default
It seems you are asking if the "motherboard" can power bigger fans. We can't tell from here, but you can use a relay. Have the motherboard run a relay and have the relay run the fans.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #5
Old 07-04-2013, 12:56 AM
Junior Member
Default
That's a good idea. Although I've never worked with relays, it's worth a shot!
  #6
Old 07-04-2013, 01:44 AM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Default
Quote:
Originally Posted by vinny8765 View Post
Model # BNA17B
115V 60Hz
1.6A
130W
The problem I have with this is fridge is that it gets my room way too hot....
If your real problem is what you stated above, the addition of fans will only change the rate at which you heat the room. The overall energy being added to the room will stay pretty much the same. A small additional amount of heat will be added to the total from the higher wattage fans you use.
Only by bringing in cooler air will you succeed in lowering the overall temperature of the room.
__________________
I'm too old.
  #7
Old 07-04-2013, 02:07 AM
Junior Member
Default
Ah okay. Any ideas on how I would accomplish this?
  #8
Old 07-04-2013, 03:01 AM
#12's Avatar
#12 #12 is offline
Default
Create a loop of outdoor air to be used by the fans.
Problem: Heat generated stays indoors.
Solution: Put it outdoors.
A tiny cooler like that might work with 4 inch clothes dryer tubing. Outdoor air comes in, gets hotter, goes back outdoors.
__________________
  #9
Old 07-04-2013, 03:22 AM
Junior Member
Default
That's a good idea, although it gets quite warm here in Texas. Not sure if the air would be cooler from outside. Maybe I should relocate to somewhere further up north. That would fix the problem.
  #10
Old 07-04-2013, 03:58 AM
Default
Put the heat sinks & fans outside the window, the fridge stays inside. Air Conditioning works like this.
__________________
Bill
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
