how to reduce the cutoff frequency of a high pass filter?
PANKAJ DHINGRA
Joined Jun 27, 2013
I m new here and this is my first thread!!
My problem is:
I have made a simple high pass filter (first order) which is just a series combination of a capacitor and a resistor of values 100pf and 35kohm resp.
so, by using the formula of cutoff frequency fc = 1/(2*pie*r*c), i found that the cutoff frequency of my circuit is 45.5khz (approx). Now, I want to reduce this cutoff frequency without changing the values of R and C. I want to know that how can we do that with the help of transistors or opamps.
P.S. : I don't want to connect capacitors and resistors in parallel to these C and R of my high pass filter .......REPLY ASAP!!
THANK U IN ADVANCE!! :)
Papabravo
Joined Feb 24, 2006
21,228
You cannot construct a passive filter with a different cutoff frequency without changing R or C.
You can make an active filter with opamps and R's and C's but it will not have the same topology as the simple passive single pole filter. A common implementation is called Sallen-Key
http://lmgtfy.com/?q=Sallen-Key
All you ever wanted to know about filters is in van Valkenberg, Analog Filter Design
LDC3
Joined Apr 27, 2013
924
My problem is:
Without changing the capacitance or the resistance, the cutoff frequency will remain the same. Transistors and op-amps are designed to work with even higher frequencies, so they will not decrease the cutoff frequency.
BTW, if you want an audio signal, you would want a low-pass filter with a cutoff at 45.5kHz. A lot of people cannot hear tones above 35kHz.
Papabravo
Joined Feb 24, 2006
21,228
@OP - where did you get the quaint notion that you could actually do what you asked about -- changing the frequency without changing the values? That is equivalent to saying the original formula is wrong or the answer is not unique. Mathematics just doesn't work that way.
