All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-26-2013, 05:23 PM
ImmortalPr1nce ImmortalPr1nce is offline
Junior Member
Default PIR Motion Sensor Project
Ok so this is my first post. I layout circuit boards for a living but im a complete noob when it comes to making schematics so i thought maybe some of you pros could help. Basicly i want to make a motion detector using a PIR sensor. when tripped i want it to sound an alarm until reset. i would also like a low battery light and maybe a remote controlled on and off. Any and all help would be greatly appreciated.
  #2
Old 06-26-2013, 05:43 PM
Dodgydave's Avatar
Dodgydave Dodgydave is offline
Default
You can buy a ready made pir sensor , and attach a timer/tone generator (555) to the output, as for remote control again ready made modules are available what is your price range?
__________________
NECESSITY IS THE MOTHER OF INVENTION !
The Following User Says Thank You to Dodgydave For This Useful Post:
ImmortalPr1nce (07-02-2013)
  #3
Old 06-26-2013, 06:03 PM
Junior Member
Default
I really want it all to be on one board/ schematic (obviously remote would be its own). i would prefer to stay away from ready made if possible.
  #4
Old 06-26-2013, 06:18 PM
Dodgydave's Avatar
Default
Your better getting the module sensor ready made rather than building your own, costs are far lower, as for all on one pcb its easy,
__________________
  #5
Old 06-26-2013, 06:29 PM
elec_mech elec_mech is offline
Default
Welcome to AAC.
While I'm not overly familiar with PIR options, I can't recall seeing PIR sensors by themselves. More often than not, they come on a small board with basic circuitry to allow you use them right away. They're often so cheap, I won't think it would be worthwhile to attempt to get the sensor alone and design a driver circuit for it.
That said, you can add a set of female headers to your board and just plug the sensor into it. I've helped others use the Parallax PIR sensor which you can pick up at RadioShack if you're in the U.S. If space is an absolute premium, you could buy the PIR sensor, reverse engineer the small board, buy the components and desolder the PIR sensor itself to use on your custom board.
You can take a look at this thread to get you started on hooking up a PIR sensor. You can use a flip-flop to keep the alarm going once PIR sensor is tripped and until someone presses a reset button.
I haven't done a low battery indicator before, but I'm sure we can help you find something.
When you say remote control are you referring to a wired or wireless remote? If the latter, you can use a children's RC toy. Will depend on the range you want though.
The Following User Says Thank You to elec_mech For This Useful Post:
  #6
Old 06-27-2013, 11:57 AM
Junior Member
Default
digikey has some of the PIR sensors by them selves. but yes you both are right the pir with the board would probably be the best option. yes i was thinking flip flop for the alarm but am unsure on how to hook up the reset. as for the remote i was thinking almost like a car alarm key fob you point it at the unit push the button and it turns it on and off. again was thinking flip flop for this to would that work?
  #7
Old 06-27-2013, 10:14 PM
Default
For the remote, another member recently found this. If we understand it correctly, you can set each channel to act as a momentary or latch switch. You could set up one channel as a latch to turn the circuit on and off and another as a momentary for the reset portion. If you want to keep it dirt simple, the on/off can be reset - turn the power off then on again to reset the circuit.
The simplest approach that comes to mind is an SCR. Once the PIR sensor trips, it will turn on the SCR which would be connected to your alarm. The SCR then remains on (and thus the alarm) until power is removed. I haven't used one of these myself, so perhaps someone else can suggest a part, but if not, I can research something for you.
The Following 2 Users Say Thank You to elec_mech For This Useful Post:
djsfantasi (06-27-2013), ImmortalPr1nce (07-02-2013)
  #8
Old 06-28-2013, 04:31 AM
JohnInTX's Avatar
JohnInTX JohnInTX is offline
Default PIR preamp example
This is from an old project. The PIR detector P/N is lost to history but it was a raw PIR in a TO-5 can with a window on top. Anyway, similar devices are likely available still.
These generate a SLOWLY changing, HiZ output with changes to detected body heat.
The circuit comprises a 2 stage AC coupled amplifier. The output (U3-7) swings slowly around in response to sensed heat. In this circuit, the output is fed into a window discriminator (HISENSE/ and LOSENSE/) which went to a microcontroller. The SENSITIVITY pot moved the high and low thresholds apart to set where the movement was enough to signal the code that motion was happening. Motion was defined as a voltage excursion in the high or low direction.
I don't remember much else about it except that I got stiffed on the project so quickly lost interest in archiving it - hence no BOM. .
EDIT:
I think the sensor was something like the Murata IRA-E700ST0 (Digikey) The circuit looks familiar..
All said, I agree with the others that an integrated sensor, off the shelf setup is pretty attractive..
__________________
We learn to do neither by thinking nor by doing; we learn to do by thinking about what we are doing.
George D. Stoddard
The Following User Says Thank You to JohnInTX For This Useful Post:
  #9
Old 06-28-2013, 12:01 PM
Junior Member
Default
Thanks everyone for the help so far. looking at that last schematic I realize this project is a bit above me. so the question is what would someone charge to make me a schematic? well 2, 1 for the main board and one for the remote (preferable in diptrace) that does what I want it to do? with little to no coding.
  #10
Old 06-28-2013, 12:20 PM
Default
If you're okay using a ready-made PIR module, you won't need anything quite as involved as John's schematic - he's, in effect, showing you what is on the boards of the ready-made PIR sensors - hence the advice of the rest of us to stick with ready-made.
Are you trying to put this into a tiny-as-possible package or would a small package work? If the latter, use a ready-made PIR module and we can help you design the schematics to do what you want. This becomes dirt simple using a PIR module with an SCR and an alarm - three parts and a few passive components.
The battery indicator will add some parts, but I don't foresee that being complicated either. How do you want that to function? Green LED when battery is good, yellow for low, red for dead? Or just a red LED to indicate when the battery is low (thereby prolonging the battery life)?
Remote module will probably be the biggest item if you go with something simple and cheap. Even then, I'd guess you could fit everything into something the size of soup can (maybe a little bigger). Would this work?
Tags
Related Site Pages
Section Title
Worksheet Flip-flop circuits
Worksheet Servo motor systems
Worksheet Linear computational circuitry
Worksheet Oscilloscope trigger controls
Worksheet Switches
Worksheet Physical effects of electricity
Video Lecture Inductors (Part 1) - Inductors,Capacitors,Transformers
Textbook Synchronous counters : Sequential Circuits Counters
Textbook Conventional versus electron flow : Basic Concepts Of Electricity
Textbook Conductors, insulators, and electron flow : Basic Concepts Of Electricity
Similar Threads
Thread Thread Starter Forum Replies Last Post
PIR MOTION SENSOR + LED problem Arhont The Projects Forum 22 01-10-2013 12:35 PM
PIR motion detector with timer switch embryolk The Projects Forum 0 08-12-2012 04:33 AM
how to make timer 555 reset using PIR motion terabyte The Projects Forum 13 03-09-2012 05:58 AM
PIR motion detector allenpitts The Projects Forum 3 08-18-2011 06:46 PM
Where can I buy a PIR motion sensor? przachar General Electronics Chat 6 03-05-2010 07:55 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
