1 Stick Radio Control
xoxorockoutloud123
Joined Jun 17, 2013
16
Are there any cheap radio controllers out there that have only one up/down stick for use with a single Electronic Speed Controller? I plan on using this for throttle. Also, which receiver would pair well with the controller? I have a budget for this of $20 but cheaper is better. Also, if it is any help, I plan on using this ESC:
http://hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6458
Specs:
Weight: 24g
Cells: 2-3S (Auto Detect)
Max Current: 25A
Burst: 30A
BEC: 3A
34,947
My first RC plane used a radio transmitter that had a single push button. It controlled the rudder. One press made the rudder go one way. Two presses and the rudder went the other way. The motor for the rudder was a rubber band. The radio receiver controlled a latching solenoid mechanism called an escapement.
