AC to DC converter
ferdowssanehi
Joined Jun 18, 2013
I took my old phone power supplies and opened it up.
I need help to reverse engineer it because instead of a 5V output, I want a 24V output
can anyone help me to learn more about this circuit , or sample schematics
im a second year electrical/computer engineer,
i dont know why there is a IC chip there , and i dont know about that transformer(yellow component).
much thanks !
bountyhunter
Joined Sep 7, 2009
2,512
They are typically some kind of cheap off line flyback converter using dedicated ASICs made specifically for the application. I wouldn't try to reverse engineer it and I used to design them. I'd go to ebay and buy a cheap 24V cube, probably $5.
BTW: going from 5V up to 24V would require rewinding the transformer and replacing a lot of components even if it is possible.
absf
Joined Dec 29, 2010
1,968
If pins 5-8 are all connected together and goes to the primary side of the transformer, there might be a chance that the chip is a Viper22AS, see pdf attached.
This type of 5V supply normally only gives 500mA like the USB (I guess). So 0.5A x 5V= 2.5W. If you step it up to 25V, then the current would be reduced to 2.5 / 25= 100mA. As bountyhunter has pointed out, you have to rewind the secondary coil and change the values of some of the components. I doubted if it is worth the effort to do all this. But if you just want to experiment with it, then it's OK. :D
But be really careful... as there is live AC voltages there...
Allen
Dodgydave
Joined Jun 22, 2012
11,395
You wont be able to do it as the SMPS is designed to give approx 1.8 times the output it needs, so the maximum open circuit voltage would prob be 10V at best.
