Converting Byte Array to Unsigned long Array
eng.me
Joined Dec 10, 2012
27
Can some one help me to convert the following byte array to unsigned long array
Rich (BB code):
uint8_t data [8] = { 0x67 , 0x45 , 0x32 ,  0x01 ,  0xEF ,  0xCD ,  0xAB ,  0x89 };
I need to convert it to :
Rich (BB code):
 unsigned long data [8] = { 0x01234567 , 0x89ABCDEF };
WBahn
Joined Mar 31, 2012
32,919
How that behaves is going to depend on the endiness of the machine -- this is geared to a little-endian machine.
Also, I don't know that the size of a long is rigidly fixed at 32 bits versus just having a minimum width of 32 bits. It would be better to use something like uint32_t, instead.
Finally, this won't work for the values given by the OP, though I suspect the cause is a simple typo.
