LED Color Organ Mod problem
ajaxoftherockies
Joined Apr 7, 2012
26
Hi Gang
I built this LED Color Organ - http://blog.makezine.com/2010/10/18/circuit-skills-led-color-organ-spon/ - and it works great.
Wanting more, I modified it to drive three high-power LEDs - 400ma each
Problem is that I don't have the circuit around the TIP120 Darlingtons right exactly. the Red channel works really well, but the Blue & Green channels are difficult to balance, and after a while operating, the Blue channel just stays on - even if I disconnect the input to the base.
Also, when I turn on the power, all three LEDs glow a bit. Drawing about 11ma total, even with the base input disconnected, so it seems that the TIP120s aren't totally turned off.
Here's the circuit with my modification boxed in on the right side.
Can someone here tell me what I'm missing? I'm not a total electronic noob, but know enough to be dangerous. (as may be obvious)
Thanks!
- a -
wayneh
Joined Sep 9, 2010
18,125
The drawing shows the LEDs backwards, but let's assume that's just the drawing.
If you imagine no signal coming from the left, your transistors and LEDs will be biased to on, but the base current is limited to what comes through the 100k resistors from Vcc, i.e. not much. That's why the LEDs are dim.
You need a better biasing scheme.
Bernard
Joined Aug 7, 2008
5,784
LEDs are shown backwards.
R 9, R 24, & R 29 seem a little low. I would think they should be adjusted so that LEDs are just extinguished without signal.
ajaxoftherockies
Joined Apr 7, 2012
26
Thanks, yes, the backwards LEDs are just the drawing - threw it together in a hurry to make this post.
I thought the bias was the problem, but I don't really understand how to do it and how it works.
I'll try making some adjustments - trial-&-error style - per Bernard and report back what I find.
Thanks guys!
ajaxoftherockies
Joined Apr 7, 2012
26
So, trial & error found that 180K set the LEDs to just barely glowing without input signal, so I settled for 220K (next up in my parts drawer).
When I turned the music back on, the LEDs barely flashed. So, I changed the base resistors to 1K. Then, the Red & Blue worked pretty good, but Green was barely working unless I turned P3 all the way up.
Next, I changed R28 to 820ohm (next lower in the drawer) and that seemed to help.
Here's the current circuit (with LED polarity fixed to match the actual circuit)
ajaxoftherockies
Joined Apr 7, 2012
26
Another question; i seem to recall someone saying that removing caps C12, 13 & 14 would make the LEDs react more quickly. That so? (kinda seems like it to me).
THX!
