I have built an oscillator using an HC4060 chip and a 4MHz crystal. The circuit is that in the manufacturers data sheet. The crystal is designed for an 18pF load, so I used 39 pF capacitors to ground from each end of the crystal. The oscillator starts up instantly and operates with a supply down to less than 3 volts. My problem is that it is slightly high in frequency (about 25 ppm). This is just inside the crystal manufacturers spec, but not accurate enough for my application. I believe that the oscillator frequency can be pulled by increasing the values of the load capacitors, and my question is how much pulling is possible? Is 25 ppm plausible, and if so how do I calculate the capacitor values required? I tried increasing the capacitors to 100pF to see the effect, but the oscillator became reluctant to start up. Any help appreciated.
TIA
Mike
TIA
Mike
