So I am in the process of making a bicycle power generator, but am confused with parts of the circuit and what will be required.
I am using:
1. a 12V (3ma i thin) CIM motor as the generator, it will be hooked up to a bike trainer stand. PEDAL POWER IS FREE
2. I am receiving a bunch of 12v rechargeable large capacity batteries for free. Now i know the addition of more than one battery will increase the voltage as well. Will i be able to charge the batteries through the twelve volt generator?
3. Next i figured i needed a transformer to drop the voltage down (from the voltage equal to the amount of batteries i get) to 12v for the power inverter.
4. The power inverter will finally convert the DC TO AC current and allow me to run standard outlet appliances.
So the additional batteries are only important because I want longer use out of them before they deplete and need to be charged again. But im not sure this will work due to the lower voltage needed for the inverter. So if anyone has any ideas please let me know. Feel free to critique or improve the circuit .
I am using:
