common-mode behavior of differential amplifier
screen1988
Joined Mar 7, 2013
310
Can anyone shed some light on this short section from my book?
Here is common-mode behavior of differential amplifier:
What happens if VinCM = 0? Since the gate potential of M,and M2 is not more
positive than their source potential,both devices are off,yielding ID3=0.
This part is from the book. I want to ask a stupid question. How can you know that the gate potential of M1 and M2 is not more positive than than their source potential?
Is the smallest potential in this circuit possible only zero? There is no negative potential at any nodes in the circuit.
Jony130
Joined Feb 17, 2009
5,598
Your understanding of how this circuit behaviour for Vcm = 0V is correct.
For Vcm = 0V M1 and M2 are OFF because even if M3 is in triode mode.
M1 and M2 source voltage is equal to 0V.
Vgs = Vg - Vs = 0V - 0V = 0V and Vgs<Vt ---->OFF
screen1988
Joined Mar 7, 2013
310
That is not mine. :) It is Razavi's!
My confusion is how can you know that M2 and M3 are OFF.
I want to check the condition Vgs < Vth but in this case how can you know the voltage of source S is zero?
Is it possible that the voltage at the source S negative? Then Vgs can be larger than Vth. And M1 and M2 are ON.
screen1988
Joined Mar 7, 2013
310
Simply assume the M3 is full ON. So Vds3 ≈ 0V
Not sure about this. What do you mean full ON? When it is ON, it can be in saturation or triode region. But when I see the characteristic graph, if trans is in saturation its voltage is very large.
Do you see any negative voltage in the diagram?
Nope, maybe it is only in my imagination.
kubeek
Joined Sep 20, 2005
5,796
The voltage at point P can only be somehere between 0 and Vdd. So if Vin is at 0 then M1 and M2 will be off no matter what.
