All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-29-2013, 07:42 PM
Nano001 Nano001 is offline
Member
Default Issues with capacitive coupling of 2 opamps
Hi, I built the attached circuit which I am using to detect low levels of optical pulses. I am using the first opamp as a transimpedance amplifier and the second one to amplify the signal from the TIA. The 1uF capacitor and 10k resistor is used to remove the dc signal of the first amplifier.
The circuit works well, except that there is a background frequency (about 1 khz) when there are no optical pulses which I am trying to remove. I noticed that this background oscillation is only present when I couple the two circuits with the 1uF cap. When I probe the output of the first amplifier both before and after the 1uF capacitor when it is NOT connected to the 2nd opamp, there is no oscillation. As soon as I connect everything together I see oscillations before and after the capacitor (points A and B in the diagram), and these oscillations get amplified at the output of the final opamp (point C). So, my problem lies with capacitive coupling of amplifiers.
I have tried many combinations of different R and C values, and 1uF and 10k gives me the best output signal with minimal oscillations. However, I am looking to completely remove them. The circuit works without oscillations if I completely remove the 1uF and 10k component, but the DC signal out of the first amplifier is always varying which makes it nearly impossible to set the non-inverting bias point of the second stage always equal to the middle of the first amplifier pulse.
Please let me know if you can help with this circuit, thanks.
  #2
Old 05-29-2013, 08:46 PM
MrChips's Avatar
MrChips MrChips is online now
Super Moderator
Default
With low level signals and sensitive circuits I avoid using multiple amps in an single package. I stick to one amp per package.
The other thing is two inverting amplifiers make a non-inverting amplifier which produces positive feedback. Any chance you can change the second stage to non-inverting?
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
The Following User Says Thank You to MrChips For This Useful Post:
absf (05-29-2013)
  #3
Old 05-29-2013, 10:02 PM
#12's Avatar
#12 #12 is offline
Default
Good idea. 2 inverters makes an oscillator if there is even a tiny bit of coupling through the power supply or radiated energy. Simple solution: Don't invert twice.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #4
Old 05-30-2013, 01:16 PM
Member
Default
Ok, that is a good suggestion. I will try it out.
  #5
Old 05-30-2013, 01:50 PM
ramancini8 ramancini8 is offline
Default
Try terminating the photodiode to lower the impedance of the inverting op amp input.
Tags
Related Site Pages
Section Title
Worksheet Switched capacitor circuitry
Worksheet Performance-based assessments for analog integrated circuit competencies
Worksheet Opamp oscillator circuits
Worksheet AC negative feedback opamp circuits
Worksheet Negative feedback opamp circuits
Worksheet Oscillator circuits
Worksheet Multi-stage transistor amplifiers
Worksheet Class A BJT amplifiers
Textbook Input and output coupling : Bipolar Junction Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ideal OpAmps... TheCatcher General Electronics Chat 31 05-31-2012 01:47 PM
Capacitive coupling epsilonjon Homework Help 9 01-03-2012 07:52 PM
Capacitive touch pad R!f@@ General Electronics Chat 7 12-26-2010 06:25 PM
Issues relates capacitance in a high pass filter/ac coupling trytolearn General Electronics Chat 7 04-10-2010 04:43 PM
Capacitive coupling due to parasitic capacitance. alphacat General Electronics Chat 4 11-15-2009 05:00 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
