How to construct a PWM circuit using 2 Timer 555
cloud623
Joined Dec 16, 2007
9
i try already using many method construct the PWM, but i found that timer 555 and easily control the waveform and build the cicuit. So anyone can teach me use 2 timer 555 build the PWM circuit.
cloud623
Joined Dec 16, 2007
9
thanks a lots u 2 guys. but i mean one 555 is as a Voltage-controlled oscillator, another one is PWM 555. so refer below i attached Voltage-controlled oscillator 555 and other 2 PWM 555. How to combine can be adjust the pulse width by using voltage control.
Ron H
Joined Apr 14, 2005
7,063
If you want variable frequency, and variable duty ccle, and you want them to be independent of each other (duty cycle doesn't change when you change frequency), I don't think you can do it with a couple of 555s. Maybe not even with 100 555s.:D You can do it with some other parts, though.
cloud623
Joined Dec 16, 2007
9
thanks a lots, Mr. Ron H. May i ask one question is the diagram you given that 555 pin 7 and pin 7 are not need to connect or need to connect other circuit?
Ron H
Joined Apr 14, 2005
7,063
Why are you wasting days asking pointless questions? I posted the schematic 10 days ago. You could have built it and tried it out in a few minutes.
If you are reluctant to order parts until you are sure it will work, then tell us that. As you can see, we're starting to get annoyed (or at least I am).
gootee
Joined Apr 24, 2007
447
And if you don't have the parts, or the test equipment needed, you could at least download the LTspice circuit simulator from http://www.linear.com and test the circuit that way. You can change component values and see whatever waveforms you want, etc etc.
