All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-24-2013, 06:21 PM
rayraysayshi rayraysayshi is offline
Question How to attenuate an undesired signal
Hello, I am working on some homework and wish to learn how to attenuate a strong signal so it doesn't interfere with another desired frequency. My question is; a strong signal at 2.45 MHz is interfering with an AM signal at 980 Hz. Design a filter that will attenuate the undesired signal by at least 60 dB.
First I extract given data;
2.45 MHz (signal to be attenuated)
980 kHz (desired signal)
60 dB (factor which undesired frequency needs to be attenuated)
I know I wish to implement a low-pass filter but I dont know how to go about creating a circuit from the 3 given values. I tried to use the voltage gain relationship, Gain [dB] = 20log(Vout/Vin) but, this just gives me Vout/Vin which I fail to see useful when I am only given an undesired frequency and a desired one.
I'm confused what order the filter needs/can be. I'm confused about how to get the transfer function from the given information. I believe once I have the transfer function I can draw the circuit.
Any ideas, obvious misunderstanding or suggestions? Thanks for reading.
  #2
Old 04-24-2013, 06:26 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
I assume you are talking about a 980 kHz AM signal and not a 980 Hz signal, wich would be audio.
You could try to make a notch filter tuned to the 2.45 Mhz.
See this wiki page for more info:
http://en.wikipedia.org/wiki/Band-stop_filter
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 04-24-2013, 06:39 PM
Default
I'm reading about notch circuits right now and this seems like the right approach; via wikipedia;
"...that passes most frequencies unaltered, but attenuates those in a specific range to very low levels. It is the opposite of a band-pass filter. A notch filter is a band-stop filter with a narrow stopband (high Q factor)."
  #4
Old 04-24-2013, 06:44 PM
#12's Avatar
#12 #12 is offline
Default
Filters are rated at db/decade. I forgot how many. How many decades of frequency do you have to work with? A little over 2. Will a single pole filter do 30 db per decade? I don't think so.
See me trying to arrive at what order of filter will be required?
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #5
Old 04-24-2013, 06:54 PM
Default
Quote:
I'm reading why it should be a little over 2 now, I don't fully understand dB/decade.
Okay...I'm starting to see some equations appear; first I converted the frequency to radians/s:
2.45 MHz = 15.39E6 rad/s
980 kHz = 6.157E6 rad/s
and now log(15.39E6/6.157E6) = 2.5 decades which means I will need more than one pole in the denominator.
Last edited by rayraysayshi; 04-24-2013 at 07:12 PM. Reason: progress on understanding how dB relates to decades, conversion of Hz to radians/s
  #6
Old 04-24-2013, 07:09 PM
#12's Avatar
#12 #12 is offline
Default
Oops. It's not 2. It's a bit over 1 decade. 1Mhz is 10 times 100KHz.
Let me google that for you:
http://en.wikipedia.org/wiki/Decade_%28log_scale%29
http://www.soundfirst.com/Filter_Slopes.html
__________________
The Following User Says Thank You to #12 For This Useful Post:
rayraysayshi (04-24-2013)
  #7
Old 04-24-2013, 07:17 PM
bertus's Avatar
Administrator
Default
If the Q of the LC filter is high enough, it would be no problem to eliminate the 2.45 Mhz signal.
A series LC circuit would already be a simple solution:
How would it otherwise be possible to recieve a single station on the radio?
Bertus
__________________
The Following 2 Users Say Thank You to bertus For This Useful Post:
#12 (04-24-2013), rayraysayshi (04-24-2013)
  #8
Old 04-24-2013, 07:34 PM
#12's Avatar
#12 #12 is offline
Default
Darn. I wasn't even THINKING in RF terms.
__________________
  #9
Old 04-24-2013, 07:48 PM
Default
So a second order circuit is now in my crosshairs...There are second-order bandstop* filter equations;
http://imgur.com/u5rAqju
I wouldn't be able to tune to a different station if I've adjusted my Q factor very high--it would only tune into that frequency. But for now I am assuming that I don't care about receiving any other frequencies and only care to receive the AM.
  #10
Old 04-24-2013, 08:37 PM
crutschow's Avatar
crutschow crutschow is offline
Default
If you wanted to use a low-pass filter you would select a corner frequency somewhat above the desired frequency (so it isn't appreciably attenuated) say 1MHz. From that to the 2.45MHz frequency is a little over an octave so you want a rolloff of near 60dB/octave. This can be accomplished with an 8th-order Butterworth filter or a 6th-order Chebyshev with 0.5dB passband ripple, which would require 4 or 3 high-speed op amp 2nd-order Sallen-Key filters respectively.
That becomes fairly complex so perhaps Bertus's design to use a resonant notch filter for the desired attenuation would be preferable. But you may need some way to tune the notch frequency to compensate for component tolerances.
__________________
Zapper
Curmudgeon Elektroniker
Tags
Related Site Pages
Section Title
Worksheet Active filters
Worksheet Elementary amplifier theory
Worksheet Performance-based assessments for AC circuit competencies
Worksheet Passive filter circuits
Worksheet Decibel measurements
Worksheet Mixed-frequency signals
Textbook Resonant filters : Filters
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook The common-base amplifier : Bipolar Junction Transistors
Textbook Attenuators : Amplifiers And Active Devices
Similar Threads
Thread Thread Starter Forum Replies Last Post
4-20mA Output Signal Degradation dwinter General Electronics Chat 8 09-03-2012 04:49 AM
AM Modulation Taught Wrong? (And What's Right?) autodidact Radio and Communications 72 07-19-2012 06:54 PM
Project: Converting Audio to 0-4VDC Signal for Animatronics djsfantasi The Completed Projects Collection 0 10-26-2010 01:11 PM
Signal to Noise Ratio for audio circuit KrisUK General Electronics Chat 12 03-03-2009 04:21 PM
oscilloscope invert mode and ADD mode relicmarks General Electronics Chat 10 04-11-2008 03:16 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
