All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-23-2013, 03:38 AM
davidGG davidGG is offline
Member
Default Transformer/Heatsink question
Hello everybody,
I have a transformer rated at 36VCT 0.8A. If I use a rectifying diode and a voltage regulator (LM 317T) to lower the voltage to 5VDC to charge my kindle fire rated at 5V 1.8A, will the transformer be able to handle this current?
Also, the rectified voltage is 10VC which means I will be dropping 5V, so the total power dissipated will be 9W! Will a standard heat sink suffice or should I design this project differently?
Thank you for the help
Transformer link: http://www.allelectronics.com/make-a...SFORMER/1.html
Heat sink: similar to
http://www.ebay.com/itm/2-Pcs-TO-220...item337cba997a
edit: yes I know I can just buy a wal-wart and simplify everything but I'm trying to use the items I currently possess before buying anything new.
  #2
Old 04-23-2013, 03:44 AM
gerty gerty is offline
Default
The transformer you want to use isn't a good fit, voltage is too high, current too low. Maybe this'll help answer some questions.
http://www.hammondmfg.com/pdf/5c007.pdf
  #3
Old 04-23-2013, 04:02 AM
Member
Default
Thank You.
Just to clear things up for the future, if the transformer is rated at 36V 0.8A, I can NOT draw 1A at 5V? Meaning 0.8A is the absolute maximum I can draw (without dieing)?
  #4
Old 04-23-2013, 04:47 AM
Default
Quote:
Originally Posted by davidGG View Post
Thank You.
That's correct .8 amps is max. And to regulate the voltage down to charge a 5 v battery, you'll have to drop about 40 volts across the regulator, which is way too much.
  #5
Old 04-23-2013, 08:35 AM
crutschow's Avatar
crutschow crutschow is offline
Default
1.8A @ 5V from a 36V 0.8A source can be done using a switching buck regulator. The practical maximum including the switcher efficiency and proper transformer derating would give about 3A @ 5V.
__________________
Zapper
Curmudgeon Elektroniker
  #6
Old 04-23-2013, 07:46 PM
Default
Hello everybody,
I was trying to keep within the posters specs,,,
  #7
Old 04-23-2013, 10:00 PM
Potato Pudding Potato Pudding is offline
Default
Using a switcher as either a preregulator or for all of the regulation will help you get your voltage down AND your current up.
That is efficient.
Basically you can drop a switched pulse of 1.8A current across an Inductor, down from 50 to 5V.
An input filter capacitor will smooth out that 1.8A to less than 0.8A continuous from the transformer. In fact that input current will likely average around 200milliamps.
The magnetic field in the inductor will have enough power at a low duty cycle to provide the 1.8amp current during the off switched cycle.
RB has a two transistor switcher design on his website.
__________________
Do what it takes to get what you want.
Take what you get while you do what you want.
Choice is pretty much up to you.
  #8
Old 04-23-2013, 10:49 PM
#12's Avatar
#12 #12 is offline
Default
With what you have, the bottom left drawing in the Hammond document is the best way to go analog. You will get .8A DC with about 24V on the first filter capacitor. That's 3 times the voltage you need, demonstrating that this transformer is really not right for your needs.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question About Magnetic Field's and Refractive index? wes Physics 6 06-08-2010 12:17 AM
Digital Logic Question (exam is tomorrow!) jetpac Homework Help 5 04-29-2010 09:03 PM
one last question? Mathematics! General Electronics Chat 15 03-02-2010 08:05 PM
Question to 'Beenthere" mainly Chris15 The Projects Forum 5 12-21-2009 09:11 PM
Question about temperature dependence of Battery capacity steveb General Electronics Chat 39 11-26-2009 11:16 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
