I tried my best to adjust the circuit components but failed too many times. I tried to cascade two MAX2611 to give me 100 voltage gain but the problem is the oscillation and sometimes the input will be distorted! I have no idea why the signal from the signal generator can be distorted??? It is so strange and why individual amplifier can work but use a coupling capacitor to connect them then oscillation will happen. I don't know what should I do to add somewhat phase margin. Except the ground and voltage regulator I cannot find any feedback path for such oscillation happened. Are there some useful technique to properly isolate amplifiers?
If I want to achieve 1000 times gain to amplify a -60dBm signal, what should I do?
