Hi all,
I have designed (tried to design maybe?) a 500mA LED boost driver based around the LM3410X LED driver. The completed schematic for my driver is below. Apologies if my nomenclature is off...
The control circuit half of the driver is based around an ATMEL ATTINY 13V micro-controller and incorporates some external parts for battery voltage detection, reverse polarity protection and thermal protection. The PWM input of the LM3410 chip (SOT-23) is driven by pin 7 of the ATMEL chip. I know the control half of the circuit works as it is currently humming along nicely in a simple linear regulator driver I built recently.
Anyway, for the boost converter half I am relatively confident it's correct as it is more or less based around the circuit depicted in design example 4 of the LM3410 datasheet (page 28). The only difference is I have boosted my output current from 340mA to 500mA.
A few questions and notes:
1) I can't for the life of me figure out why they have R1 and R3 in parallel in design example 4. Why not a single resistor as per pretty much every other design example in the datasheet? I went with a single resistor and set it to provide me with my desired LED string current.
2) I've listed the Schottky diode as needing to be greater than 500mA and 10V - this is because I have not started looking for a suitable component yet.
3) I need help picking a suitable inductor. The maths isn't beyond me but my fundamental understanding of inductors is lacking, and I want to make sure I pick a suitable part for the job. Footprint size is an issue so if I can get some parameters to look for (and obviously an explanation as to how these values were arrived at) I can go hunting for the part myself.
That's about all of got. If anyone notices anything wrong with the circuit, or even ways to improve it, I would be very appreciative.
Thanks,
- Matt
Thanks,
- Matt
