All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 03-25-2013, 08:17 PM
milosz125 milosz125 is offline
Default rectifier problem
Hello All
I have problem with electric drive project.
The drive consist of 220V DC motor (classic with brushes ) and control circuit which controls the motor. Motor is controlled in left/right style via two contactors.
The available power supply is 230 V AC 50 Hz (European type) 1 phase - TN-C type (L and PEN wires).
To supply the motor, a bridge rectifier is used. However without seperation transformer; drawing is attached to post.
My question is , is it done correctly to supply that motor in that configuration ?
What type of system is that part behind bridge?
I think grounding should be done carefully because if negative (-) wire of DC side will be grounded, it causes (when AC current starts to flow in negative period) high faulty current flow from source, through earthing, (-) wire, diode D1 and to source (V1).
So in DC side connection between negative wire and PE wire is not allowed.
Anyway designer of that circuit claims that everything is correctly designed.
Are there any regulations concerning AC/DC system interaction?
Please help.
Greets
  #2
Old 03-25-2013, 09:41 PM
BillB3857's Avatar
BillB3857 BillB3857 is offline
Default
Look at your circuit. Does it make any sense at all to have ground at both ends of the lower right diode? Likewise, you are right about high currents through D1 on the negative transitions of the AC line. Remove the ground from the motor lead.
  #3
Old 03-26-2013, 12:07 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
This is very close to being a transformerless power supply, which is against our Terms of Service. I am going to close this thread due to this.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
Tags
Related Site Pages
Section Title
Worksheet Precise diode circuits
Worksheet Bipolar junction transistors as switches
Worksheet Basic AC-DC power supplies
Worksheet Rectifier circuits
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Rectifier/filter circuit : Discrete Semiconductor Circuits
Textbook Voltage multipliers : Diodes And Rectifiers
Textbook Clipper circuits : Diodes And Rectifiers
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Vox guitar amp problem efdi The Projects Forum 21 12-17-2011 02:43 PM
PLEASE HELP!!! Rectifier issues! Moha99 General Electronics Chat 4 11-20-2011 08:11 PM
AD594 Thermocouple Interference and Ground Capacitance Problem delmasli General Electronics Chat 10 02-17-2011 04:24 PM
Bridge Rectifier Problem when connected to Wall Power Outlet richeek.arya General Electronics Chat 21 11-10-2009 08:00 PM
Laptop screen problem mentaaal General Electronics Chat 16 07-28-2009 02:04 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
