| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
I would like to know what formula(resonant frequency) to use for a
cmos hex inverter(CD4009) based oscillator/PWM circuit I am building to power a 36 volt PMDC motor?? ![]() I have read somewhere that a frequency of 1500 Hertz would be sufficient for the output powerfet's. Thanks. |
#2
Instead of the CD4009, use a CD4093, which is a quad 2-input NAND gate with Schmitt triggers on each input. The CD4009 does not have Schmitt triggers on the inputs, and slow-transitioning signals on such IC's are not good, as that can lead to high current consumption along with resultant heating of the IC.
If you go to National Semiconductor's website: http://www.national.com and download the datasheet for the CD4093BC, you will find a schematic and formula for determining the frequency of a Gated Oscillator in the "Typical Applications" section, starting on page 4. To modify the circuit so that it always oscillates, tie the two inputs together, or tie the CONTROL input to Vcc (logic "1"). As always with CMOS, ensure to tie any unused inputs to either ground or Vcc to prevent uncontrolled oscillations.
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Last edited by SgtWookie; 12-07-2007 at 04:25 PM. |
| Tags |
| formula, frequency, hex, inverter, oscillator, resonat |
Related Site Pages
| Section | Title | |||
| Worksheet | Opamp oscillator circuits | |||
| Worksheet | Design Project: Pulse-Width Modulation (PWM) signal generator | |||
| Worksheet | Design Project: Radio transmitter | |||
| Worksheet | Oscillator circuits | |||
| Worksheet | Fundamentals of radio communication | |||
| Worksheet | Resonance | |||
| Textbook | Oscillator circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits | |||
| Video Lecture | Op Amp Applications - Active Filters - Op Amps and Op Amp Circuits | |||
| Video Lecture | Basic Amplifier Configuration (Part 1) - Op Amps and Op Amp Circuits | |||
| Textbook | 555 HYSTERETIC OSCILLATOR : 555 Timer Circuits | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Resonant frequency formula manipulation. | arthur92710 | General Electronics Chat | 6 | 12-02-2007 02:44 AM |
| help on frequency formula | joe99641 | General Electronics Chat | 2 | 11-11-2007 02:50 PM |
| Oscillator, Voltage Divider, Help | cheddy | Homework Help | 9 | 10-26-2007 12:21 AM |
| Question regarding Crystal/Oscillator frequency | skysurf | General Electronics Chat | 3 | 02-09-2007 11:40 PM |
| Thread Tools | |
| Display Modes | |
