We have an amplifier here and we've had no luck in getting an amplified output.
The manual says to place a dummy 100 ohm resistor in place of the transistors to adjust the bias voltage and we did that and we set it to 0.7V. We removed that dummy resistor and soldered the MRF454 NPN transistors in place. The biasing is correct but the transistors dont seem to come on because they're very cold and there are some parts of the circuit which are very hot like some of the resistors. We thought it may be the voltage regulator but it's providing the necessary 0.7V bias to the base when we tested it with the dummy resistor.
We removed the transistors and did a diode test and it was showing 0.7V drop across BE and BC so it passed the diode tests. Could the transistors still be damaged even if they pass the diode test? We don't know what's wrong because the biasing is working correctly and we get no output. The amplifier is the AN762 by Motorola. The transistors are the MRF454 NPN.
