So, my first day of PIC programming.
I've found it is very much write and pray for the small footprint chips, no real-time debugging like I'm used to on a PC (at least not on the small PICs without more ICD hardware).
Anyway, PIC asm can get stuffed, I don't have time to learn a whole new set of opcodes so I installed the HI-TECH C Compiler, MPLAB IDE etc...
I have a "Pickit2 Low Pin Count Demo" board and a Pickit2 ISCP USB programmer.
Project: Use a PIC16F690 to gather temperatures from multiple DS18B20 digital thermometers and output to RS232 to be logged by a server.
So my idea was to output to RS232 and log temps, but before I went throwing MAX232s around I wanted to make sure the FIRST part was working (temp I/O) so the PICkit2 board has 4 LEDs on it, connected to RC0-RC3. I thought, well I'd just display nibble by nibble with a delay so I could scribble down the temp and verify it's accuracy (and just be sure that part's working before I go adding more 1-wire devices).
BUT. I get nothing, no lights.
The nibble([0-15]) function works fine, the delay_ms() works fine, and I have no idea where to go from here to debug this thing...
Help?
Schematic and code attached, power is drawn from the ICSP (USB 5v).
Help?
