All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-08-2013, 11:51 PM
Reyo Reyo is offline
Junior Member
Exclamation NE602 colpitts oscillator construction challenge ?!!
hey there experts , could you please help me on this ?
Im doing my engineering undergrad course and my final year project require to construct a a colpitts oscillator LC tank circuit in a bread board which will have a drop in frequency value as varying the inductor( the inductor am using now is fixed but will be replaced by a variable coil after making the circuit work) , one way of doing so is to use NE602 (same as SA602a) IC chip.
the chip has this pic configuration
The power supply was connected to a 150Ω resistor then to pin 8, also it was bypassed to ground with a 4n7F capacitor.
Pin 1 was grounded through a 10kΩ resistor while pin2 to through a 10nF capacitor and obviously pin3 to ground
and finally the oscillator configuration is shown below
measuring the output from pin 4 or/and 5 directly by a scope should give a frequency of 10MHz. However for some reason this didnt work, i tried couple of different values for capacitor and inductor in the LC tank according to colpitts oscillator equations but it seems its not connected to the circuit somehow.
any kind of help or tips by you engineers is very appreciated
  #2
Old 03-09-2013, 04:43 AM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Default
Drop the one cap between pins 6 and 7 and see what happens.
If it doesn't start, put a 2.2k resistor between them and look again.
__________________
I'm too old.
  #3
Old 03-09-2013, 03:43 PM
Junior Member
Default
i tried both but nothing change .. i suppose that i shouldnt measure the output directly from pin 4 & 5 maybe im missing a resistor ?
  #4
Old 03-09-2013, 05:16 PM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
This circuit oscillates in simulation (LTspice).
Note that you Have to unbalance the mixer by grounding either pin 1 or pin 2.
The duty cycle is asymmetrical, I think because the transistors in the upper half of the mixer are saturating in the model I used.
  #5
Old 03-10-2013, 05:10 PM
Junior Member
Default
Actually both pin 1 and 2 are grounded by 10kΩ and 10nF respectively
thanks for answering anyway
  #6
Old 03-11-2013, 05:13 AM
Ron H's Avatar
E-book Developer
Default
What do you mean, "thanks for answering anyway."?
You said you couldn't get it to oscillate. I showed you one way to do it. I had failed to notice that you had pin 1 grounded through 10k, but oscillation has nothing to do with pins 1 and 2.
  #7
Old 03-11-2013, 03:23 PM
atferrari's Avatar
atferrari atferrari is offline
Default
I tested the NE602 that way with a 10 MHz xtal oscillator and worked on the first try. A small trimmer in series with the crystal allowed to vary the frequency. Had some 180 mV pk-pk at the output IIRC.
__________________
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is
  #8
Old 03-11-2013, 05:05 PM
Junior Member
Default
i meant thanks for helping me to splve thew problem, sorry if it sounded a bit weird
i think my problem is in the values of components (c1,c2,c3 and c4) in the colpitts lc tank connection (pin 6,7)
  #9
Old 03-11-2013, 05:12 PM
Junior Member
Default
Quote:
thats amazing, may you test it with a 10MHz colpitts tunable lc tank oscillator because ive been trying to do so for a while, also im kind of struggling with the value of capacitor used , c1 & c2 are obtaiend from C1=100/sqrt(F(MHz))
C2=1000/F(MHz)
but i field to get values for c3 and c4 (L is a tunable inductor )
  #10
Old 03-11-2013, 05:21 PM
atferrari's Avatar
Default
I recall trying with a tank to also get 10 MHz. Kind of worked, but I am not THAT sure. The output was much much lower.
Other than a good scope I have nothing to deal with tanks and filters.
Will try again when I return from the Patagonia.
__________________
Agustín Tomás
Tags
Related Site Pages
Section Title
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
NE602 - Calculating input bandpass filter atferrari Radio and Communications 0 02-21-2013 09:19 PM
Colpitts Oscillator design questions cork_ie General Electronics Chat 3 09-25-2012 03:25 PM
Power requirement of a colpitts oscillator Power requirement of colpitts oscillator Neyolight General Electronics Chat 1 02-27-2012 07:32 AM
Common Collector Colpitts Oscillator s15kid Homework Help 20 10-24-2011 01:19 PM
Salvage Challenge russ_hensel The Projects Forum 0 02-07-2009 09:19 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
