All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-02-2013, 06:54 PM
rburley rburley is offline
Default Gould 9500a Oscilloscope
can any one help the cmoss battery failed and the scope has lost its set up and only boots to blue intro screen.
Can any one tell me how to fix the problem
  #2
Old 03-02-2013, 08:09 PM
PackratKing's Avatar
PackratKing PackratKing is offline
Default
For starters... Is the battery spot-welded into the circuit, soldered, or have a slip-in clip arrangement.
Caution : use deliberate moves when changing a power supply for a Cmos circuit... so you don't get a repeatable pulse that may "retard" the circuit...
Does it have a ROM chip to reboot the startup protocols ?? Cmos has a bad habit of ' losing its mind ' when deprived of power.
__________________
Do it once, do it right.
  #3
Old 03-14-2013, 09:29 PM
Default fix for gould 9500a after cmoss battery replaced
When the unit is powered off , you push on the “Hold all” button and start on the unit, after two beeps you let off on “ hold all” button
The unit starts and on “ cold start” and will reset the memories
The battery on the processor board when 100% dead, will auto boot as described. When it is 50% dead, you will see strange things occur and if the system is still functional, the COLD BOOT method described will usually cure the problem as long as the scope is on.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
gould oscilloscope type 4041 satchid Electronics Resources 4 10-13-2012 08:28 AM
Oscilloscope Gould 4035 Herbie General Electronics Chat 2 08-01-2012 02:36 PM
Seeking Gould Nicolet 2090 Oscilloscope Service Manual Questor General Electronics Chat 15 07-17-2012 06:10 PM
Looking For a Gould DS4200 Oscilloscope Manual grizz1956 General Electronics Chat 1 02-06-2011 09:41 PM
gould oscilloscope manual moosehead General Electronics Chat 9 01-02-2009 06:45 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
