Hi ppl,
We currently use 433Mhz ZRT-series modems from RF datatech for 2-way remote communication between equipment. Is there a standalone repeater that you can simply place in between the equipment to boost the communication range?
I've done some research and it seems that most repeaters repeat the signal after modulating the frequency a bit... How would I know if a certain repeater is suitable for the modems we use?
**PS: We are not allowed to make modifications to the modems, so we cannot configure the existing modems for store and forward operation. We need a stand-alone "plug and play" type solution.**
Regards,
Dolalrday
Regards,
Dolalrday
