Hey guys I'm trying to build a script to modulate and demodulate an am frequency.
I have my information frequency, and carrier frequency. I modulate the signal and add noise. After I do that I run it through a halfwave rectifier and low pass and high filter. I then use a convolution to remove the noise. I then write the file to a wave file and I should be able to replay file. At the end of all this I should get something similar to the original frequency, but all I'm getting is static.
Here's my code.
close all;
clear all;
fs = 50000;
t = [0:1/fs:5];
f_cut_off1 = 10000;
f_cut_off2 = 10;
f = 2000; %input frequency
fc = 940e3; %carrier frequency
k = length(t)
input_sig = (0.2)*cos(2 * pi * f * t); %input signal
wavwrite(input_sig,fs,32,'input_sig');
carrier_sig = (0.5)*cos( 2 * pi * fc * t); %carrier signal
wavwrite(carrier_sig,fs,32,'carrier_sig')
mod_sig = input_sig .* carrier_sig + carrier_sig; %modulated signal
wavwrite(mod_sig,fs,32,'mod_sig')
%interval to randonize noise
noise = rand(1, k); %random nosie
scale = 2;
new_mod = mod_sig + noise; % mod signal + noise
wavwrite(new_mod,fs,32,'new_mod')
subplot(321), plot(t, mod_sig)
subplot(322), plot(t, new_mod)
%Apply HW Rectifier
for i = 1:k
if new_mod(i) <= 0
x(i) = 0;
else
x(i) = new_mod(i);
end
end
wavwrite(x,fs,32,'hw_rect')
subplot(323), plot(t, x)
rc1 = 1 / (2 * pi * f_cut_off1);
rc2 = 1 / (2 * pi * f_cut_off2);
%Apply Low Pass Filter
num2 = [0 1];
den2 = [rc1 1];
subplot(324), bode(num2, den2)
sys2 = tf(num2, den2);
lpf = lsim(sys2, x, t);
%Apply High Pass Filter
num1 = [rc2 0];
den1 = [rc2 1];
subplot(325), bode(num1, den1)
sys1 = tf(num1, den1);
hpf = lsim(sys1, lpf, t);
vout = hpf;
g = 20;
h = (1 / g) * ones(1, g);
y = conv(h ,vout);
wavwrite(y,fs,32,'vout')
Any ideas? I'm completely stuck.
Thanks!
Here's my code.
close all;
clear all;
fs = 50000;
t = [0:1/fs:5];
f_cut_off1 = 10000;
f_cut_off2 = 10;
k = length(t)
scale = 2;
%Apply HW Rectifier
for i = 1:k
if new_mod(i) <= 0
x(i) = 0;
else
x(i) = new_mod(i);
end
end
num2 = [0 1];
den2 = [rc1 1];
num1 = [rc2 0];
den1 = [rc2 1];
vout = hpf;
g = 20;
y = conv(h ,vout);
Thanks!
