I know this is a long shot and maybe like debugging in the dark but here goes. I have a telephone with a rotary dial, seems to be relatively new so probably a 'relaunch' of a classic (candle stick in this case).
I recieved it with the mouthpiece, reciever, bell solenoid and dialer wires all connected. However, the phone wire (the bit that plugs into the wall) was missing.
My question is, is there anyway i can back trace the circuit to find out which pins the wires should go so I could reconnect it? I have tried a few combos on a VOIP box (not going to plug it into the BT network - not yet anyway...) and managed to get a dialtone, but can't seem to hang up the connection.
I can post a picture of the circuit. I looks fairly easy to trace through - I should be able to get some decent shots if you think it would help.
Thanks in advance and sorry for the long post / if its in the wrong place.
Thanks!!!!
Thanks!!!!
