Hello.
I am designing a multi-carrier multi level inverter.
I am not discussing about that concept here.
-> I want three phase sine waveforms displaced 120 deg apart (adjustable frequency). each should be atleast 6V peak voltage. (using op-amp)
-> A triangle wave(1KHz) (using op-amp, not with ICs like XR2206)
-> A clamper circuit to clamp the triangle wave to a desired level.
see the attachment.
I have gone through the link http://www.allaboutcircuits.com/vol_3/chpt_3/7.html
I will test that circuit tomorrow. I am unable to find clamper circuits on the net. I heard that op=amp gives more reliable results compered to diode circuits.
A small startup hint is enough to start my work.
Thankyou
see the attachment.
Thankyou
