Unity Gain current buffer Zin
The Electrician
Joined Oct 9, 2007
2,986
Add a 1 amp current source injecting the 1 amp into the Zin node. calculate the voltage at that node due to the current source. That voltage divided by the 1 amp will be the impedance there.
BillO
Joined Nov 24, 2008
1,001
An amp! If it is a high Z buffer, the voltage might need to be in the mega volts!
No, don't try to pump an amp into it.
All you need is a known voltage (V) and a known resistance (R). Connect V to the input of the buffer through R and measure the current (I). Use Ohm's law to get the Z of the input stage of the buffer.
Z = (V/I) - R
Of course, that is just the DC part of it. Now you will need to calculate the Z of the LC circuit.
Edit: BTW, that looks like a pretty good equivalent circuit to me.
Ron H
Joined Apr 14, 2005
7,063
Do you suppose that would cause sparks and smoke to erupt from the paper and pencil he's working with?:D
