All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-28-2013, 12:10 PM
sirch2 sirch2 is offline
Default Set Arduino pin to High Impedance (floating)
The circuit shown below is for a 40kHz ultrasonic rangefinder. I have put together a variation of the circuit using an Arduino and not including the I2C code/connector (the original code is in Assembly with which I am not too familiar so I am rewriting it).
The reciever section includes 4 Op Amps, the middle two of which are supposed to provide selectable gain. I am assuming that I need to toggle the resistsors from High Impedance to Low (ground) to change the gain and I can set the relevat pins to OUTPUT, LOW to ground them.
My question is how do I set the pins back to floating in on the Arduino? Would it be enough to set it to HIGH?
  #2
Old 01-28-2013, 12:44 PM
MrChips's Avatar
MrChips MrChips is online now
Super Moderator
Default
There is a register called DDRA. Set this to 0 to set all pins of PORTA to high impedance.
Specifically, set the corresponding bit to 1 that you wish to be an output.
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
Tags
Related Site Pages
Section Title
Worksheet Microcontroller principles
Worksheet Multiplexers and demultiplexers
Worksheet Basic logic gate troubleshooting
Worksheet AC negative feedback opamp circuits
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Class A BJT amplifiers
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook The "operational" amplifier : Operational Amplifiers
Textbook The cascode amplifier : Bipolar Junction Transistors
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mike's Arduino Post dr micron Homework Help 0 12-30-2012 05:45 PM
High impedance voltmeter doctordiode General Electronics Chat 3 04-06-2011 02:17 PM
Need help for turning PIC16F628A's RA4 pin to high erickoh1985 Embedded Systems and Microcontrollers 5 09-05-2009 10:00 PM
Impedance Matching Mazaag General Electronics Chat 33 11-17-2008 06:04 PM
Combination Lock using PIC 16f628 draeberg Embedded Systems and Microcontrollers 5 04-25-2008 04:18 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
