All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-18-2007, 05:16 PM
ronn ronn is offline
Junior Member
Default capacitors
hi, i'd like to ask why is the capacitor discharging? Is it because the voltage where it is connected (suppose you disconnect the capacitor in the circuit and hooked those two points in oscilloscope) is going below the voltage of the capacitor and the capacitor reacts by discharging? Another question is,
can it do charge or discharge on the same path or it should it be different for both? i'm figuring out how circuit works and i'm sometimes confused with this capacitor? Any web site or books that you could recommend for some circuits explanation and how its component works in the circuit? just some basic electronic circuits.
thanks a lot
ronn
  #2
Old 11-18-2007, 05:33 PM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
AAC ebook tutorial on capacitors.
Take a look here to see if it will help.
hgmjr
  #3
Old 11-18-2007, 06:16 PM
cheddy cheddy is offline
Member
Default
A charged capacitor acts just like a battery. It has a positive and negative terminal and charge flows from the positive towards the negative terminal. It holds a specific amount of charge and it has a voltage. The interesting thing about capacitors is that they are able to release their entire charge in close to an instant and they are designed to be charged and discharges, some times up to a million times a second.
So to answer your question about why it discharges. It discharges because it has a voltage, which is a potential difference between its leads. The positive and negative leads are attracted to each other and when connected they will discharge their energy.
Tags
Related Site Pages
Section Title
Video Lecture Capacitors (Part 2) - Current Flow in a Capacitive Circuit - Inductors,Capacitors,Transformers
Video Lecture Capacitors (Part 1) - Inductors,Capacitors,Transformers
Worksheet Timer circuits
Worksheet Power conversion circuits
Worksheet Basic AC-DC power supplies
Worksheet Time constant calculations
Worksheet Time constant circuits
Worksheet Capacitors
Textbook 555 audio oscillator : Analog Integrated Circuits
Textbook Capacitor transient response : Rc And L/r Time Constants
Similar Threads
Thread Thread Starter Forum Replies Last Post
start and run capacitors FrenchConnection67 General Electronics Chat 17 09-13-2013 06:29 PM
Types of Capacitors and their selection SPQR General Electronics Chat 3 01-25-2013 12:58 PM
voltage multiplier + voltage divider charging capacitors bank electricmaniac General Electronics Chat 9 08-08-2011 07:34 PM
Are all capacitors equal WrinkledCheese The Projects Forum 8 06-05-2010 03:51 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
