All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-06-2013, 07:55 PM
lokeycmos lokeycmos is offline
Default capacitor current draw
Given a source voltage, and a capacitor value, is there a formula that will show the maximum current that the capacitor will draw until it is fully charged?
a very large value capacitor will suck a lot of current and take some time to charge. whereas a very small capacitor will draw less current and charge much faster. this current draw is what im solving for. thank you!
  #2
Old 01-06-2013, 08:07 PM
StayatHomeElectronics's Avatar
StayatHomeElectronics StayatHomeElectronics is offline
Default
Add some resistance between the voltage source and the capacitor to limit the current.
As you first connect the source to the circuit, the capacitor looks like a short so the maximum current will be determined by the source voltage and the resistor, I = V / R.
Current will then exponentially decay to zero as the capacitor charges.
__________________
Without education, we are in a horrible and deadly danger of taking educated people seriously.
G.K. Chesterton
  #3
Old 01-06-2013, 08:24 PM
Default
my issue is trying to find a proper gate resistor for a IRFP460 mosfet. the input capacitance on the mosfet is about 4200pf. the cmos ic that is driving it can only drive 8.8mA with 15v to VCC(although im using 12v vcc). if i do ohms law 12v/.0088= 1363 ohms. however mosfets are voltage controlled and usually have quite small gate resistors. i would imagine that 4200pf wouldnt draw very much at all and would work with a small resistor, but at the same time i dont want to overdraw on the IC and burn it out. btw, it is a 4047 multivibrator and im only working with about 60 hz on the gate. please help me, im lost!
  #4
Old 01-06-2013, 10:15 PM
Jaguarjoe Jaguarjoe is offline
Default
At those low currents and high gate capacitance it will take quite a bit of time to fully turn on the mosfet. It will spend lots of time in it's linear region and generate a lot of heat.
If you can find the gate "charge" (Q) probably defined in "nC" (nanocoulombs), in the data sheet, then use I = QT to determine the current it wants.
  #5
Old 01-06-2013, 10:25 PM
shortbus's Avatar
shortbus shortbus is offline
Default
Most times the reason for a gate resistor is only to prevent 'ringing' (oscillation) of the gate. You want the gate to charge as fast as possible to prevent heat in the mosfet. Use a gate driver between gate and the 4047 for best results. A driver will give more amperage to switch the mosfet faster.
__________________
New members, Please put your location in your profile details.
  #6
Old 01-06-2013, 11:42 PM
kubeek's Avatar
kubeek kubeek is offline
Default
Well, U=I*t/C so with 4.2nF and theoretically 8.8mA all the way from 0 to 12V it takes 5.7us to get to 12V. With the IC you should have some resistor in series to limit the current so that the IC can take if for long time, and the turn-on time will be about 3 times longer. Use a dedicated mosfet driver if you want to switch it more than few times a second, for 60Hz you will probably be ok, but this depends on the load you´re switching.
  #7
Old 01-07-2013, 12:23 AM
WBahn WBahn is offline
Default
Check your units. QT does not yield units of current.
  #8
Old 01-07-2013, 02:03 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
If you are worried about the power dissipated by the 4047, the power required to charge and discharge a capacitor is
P=f*C*V^2
P=60*4.2e-9*12*12
p=36.3μw
Since you are driving 2 MOSFETs, the total power dissipated by the IC (due to driving the MOSFETs) is 73uW.
You don't have to worry about the IC. However, as others have mentioned, the MOSFET dissipation will be reduced if you used high current drivers for the MOSFETs, but at 60Hz, the savings will probably not be worth it.
  #9
Old 01-07-2013, 03:37 AM
Default
Quote:
Yep, you're 110% right. I multiplied instead of dividing: I = Q/T
  #10
Old 01-07-2013, 03:47 PM
Audioguru Audioguru is offline
Banned
Default
Texas Instruments show that the typical output current of a CD4047 with a 10V supply is 10mA into a short circuit when the capacitor is beginning to charge and is 7.5mA when the capacitor is charged to half the supply voltage. The currents will be a little higher with a 12V supply.
The current is very low so the current-limiting resistor can be a small value (10 ohms to 47 ohms) to keep the Mosfet from oscillating.
Tags
Related Site Pages
Section Title
Video Lecture RC Time Constants (Part 1) - Pulse Circuit Response - Inductors,Capacitors,Transformers
Video Lecture Capacitors (Part 1) - Inductors,Capacitors,Transformers
Worksheet Switched capacitor circuitry
Worksheet Time constant calculations
Worksheet Time constant circuits
Worksheet Capacitors
Worksheet Capacitance
Textbook 555 ramp generator : Analog Integrated Circuits
Textbook Capacitor transient response : Rc And L/r Time Constants
Textbook Electric fields and capacitance : Capacitors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fourier Series, complex number draw in Matlab Gablham Homework Help 4 10-25-2012 05:05 AM
Does a Voltage Regulator Draw Power at Rest? Dan-O The Projects Forum 8 01-09-2010 02:52 PM
Software package that is used to draw Electronics circuit diagrams ranatungawk General Electronics Chat 2 10-19-2009 04:45 AM
stumbling on ac amp draw woogerboy21 General Electronics Chat 4 09-23-2008 06:15 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
