All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-05-2013, 05:09 AM
mikeonavtx mikeonavtx is offline
Red face Pneumatic door opener project
OK, I'm new to the world of electronics and stuff but i want to build a wireless pneumatic door opener for my shed. (if you have a garage, does it have an automatic opener?) My first question is how complicated or simple is this going to be.
the system should be able to control 2 doors independently.
  #2
Old 01-05-2013, 10:01 AM
Dodgydave's Avatar
Dodgydave Dodgydave is online now
Default
Pneumatic is going to need a supply of compressed air, most garage door openers use a motor and gearbox drive system, usually battery backup DC with mains charging.
__________________
NECESSITY IS THE MOTHER OF INVENTION !
The Following User Says Thank You to Dodgydave For This Useful Post:
mikeonavtx (01-06-2013)
  #3
Old 01-05-2013, 04:39 PM
abhaymv abhaymv is offline
Talking
I googled your querry, and the following result appeared:
http://www.clippard.com/downloads/PD...Pneumatics.pdf
See page 29, and you may want to glance the entire pdf. It may be useful. It deals with the basic model, if you're not familiar with it.
The way I understand it, it's more about valves and stuff, than actual electronics. But I could be wrong. If your question is about the wireless part, it could be complicated depending on what you pick. RFID? IR?
The Following User Says Thank You to abhaymv For This Useful Post:
  #4
Old 01-05-2013, 04:42 PM
Metalmann's Avatar
Metalmann Metalmann is offline
Default
What type of doors are you going to use? Steel? Overhead?
Wooden doors are much heavier.
The Following User Says Thank You to Metalmann For This Useful Post:
  #5
Old 01-06-2013, 12:36 AM
Default
Metalmann standard out-swing wooden shed doors on piano hinges. an 1 1/4'' double acting cylinder should do nicely
The Following User Says Thank You to mikeonavtx For This Useful Post:
Metalmann (01-07-2013)
  #6
Old 01-06-2013, 12:46 AM
Brownout's Avatar
Brownout Brownout is online now
Default
Quote:
...or you can use the kind that has it's own supply of compressed gas, like the ones that open a car's rear hatch. You would have to close it manually, which recharges the cylinder for the next opening. Then, you only need to activate a 'latch' that will allow the gas cylinder to open the door. It you're interested in automatic opening and manual closing, then that might do the trick.
__________________
My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention. ~Hedley Lamarr
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to post a project to the collection Dave The Completed Projects Collection 1 01-30-2013 08:15 PM
Project: PIC based Scalextric Lap Counter Crossie The Completed Projects Collection 6 03-11-2011 01:26 PM
Fan Project Help! BR14 The Projects Forum 4 02-25-2011 11:58 PM
Science project: Suggestions for timer and pull solenoids EvaM The Projects Forum 5 12-13-2010 07:31 AM
Odd project casing ideas? - Lighting project snowbarrr The Projects Forum 11 12-04-2010 08:27 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
