All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-03-2013, 09:20 AM
morphy_richards morphy_richards is offline
Default Saturated NPN base to emitter voltage drop?
I'm checking for possible problem with a simple H bridge motor control circuit I'm designing using only NPN transistors. The motor supply is 4.5 V and the base will be 'switched' using a 5 V supply.
I understand that as long as the transistor is in saturation there is no appreciable voltage drop from the collector to the emitter but what about from the base to the emitter?
Something I have read elsewhere suggests there is a 0.7 v drop here which would put the base voltage at 4.3 V and below the value of the (4.5 v) emitter voltage which means the transistor wont work as expected? Thanks for any help and advice.
  #2
Old 01-03-2013, 09:46 AM
MKCheruvu MKCheruvu is offline
Junior Member
Default
Please provide Schematic diagram to understand H Bridge and its Drive configuration.
__________________
Thank the candle for its light but do not forget the candle holder silently standing in darkness
  #3
Old 01-03-2013, 11:44 AM
GopherT's Avatar
GopherT GopherT is offline
Default
In general, you are right. Emitter will be 0.5 to 0.7 volts below base voltage (it can be more). If you have a darlington NPN, it will be double. Check your DATASHEET.
  #4
Old 01-04-2013, 02:10 AM
StayatHomeElectronics's Avatar
StayatHomeElectronics StayatHomeElectronics is offline
Default
A schematic would definitely be helpful.
If you tie the emitter of your drive transistor, npn, to 4.5 volts, the base of the transistor would have to reach approximately 5.2 volts in order to turn the transistor ON. The 5.2 volts is above both your drive and logic supplies. It requires additional "high side drive" circuitry to use only npn transistors.
__________________
Without education, we are in a horrible and deadly danger of taking educated people seriously.
G.K. Chesterton
  #5
Old 01-04-2013, 02:50 AM
tinamishra tinamishra is offline
Banned
Default
A bipolar junction transistor could be a design of transistor that relies on the get in touch with of 2 types of semiconductor for its function. BJTs are often used as built-in amps already built in, changes, or in oscillators. BJTs are often discovered either as personal individual areas, or in large figures as components of incorporated tour.
Bipolar transistors place system thus known as due to their function includes each electrons and gaps. These 2 types of cost providers place system attribute of the 2 types of doped semiconductor content. In difference, unipolar transistors like the field-effect transistors have just one quite cost service provider.
  #6
Old 01-05-2013, 02:26 PM
Audioguru Audioguru is offline
Banned
Default
Please "get in touch" with translation software that works properly.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Two simple questions, but I'm troubled by them. lajka General Electronics Chat 8 01-14-2012 03:00 PM
E-book Correction Uncorrect calculation Thevenin's Planet Feedback and Suggestions 8 12-22-2011 07:06 AM
Voltage divider bias sudar_dhoni General Electronics Chat 11 01-16-2010 01:59 PM
Voltage Divider Verification ELECTRONERD General Electronics Chat 52 09-21-2009 12:38 AM
where is the base voltage ? Thevenin's Planet General Electronics Chat 4 06-05-2009 09:40 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
