All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-01-2013, 05:51 PM
logearav logearav is offline
Default Current Divider rule
When it comes to voltage divider, the formula for calculating voltage drop across a particular resistor(Vx) is
(Rx/Total Resistance) * Source Voltage, here Rx is Resistance for which we need to calculate the voltage drop.
But when it comes current divider, the formula is
(Rtotal/Rx) * Itotal.
Why it is not (Rx/Rtotal) * Itotal as in the case of Voltage divider
Revered members,
Could you help in this regard, please?
  #2
Old 01-01-2013, 05:58 PM
kubeek's Avatar
kubeek kubeek is offline
Default
How about because it is not a voltage divider but a current divider?
Remeber that current depends on 1/R.. Why donīt you write the eqations and see what you get?
The Following User Says Thank You to kubeek For This Useful Post:
logearav (01-01-2013)
  #3
Old 01-01-2013, 06:08 PM
Default
Oh! Thanks a lot kubeek. I am a fool not to realise this basic fact. Once again i thank you wholeheartedly from the bottom of my heart. My teacher too didn't tell this. You have put as simple as that. Wonderful!!!
  #4
Old 01-02-2013, 12:27 AM
WBahn WBahn is offline
Default
You should work out all of the basic formulas that you use from basic concepts. Why do resistors in series add? Why do resistors in parallel add the way they do? Both formulas can be easily derived by applying the constraints imposed by the circuit. Resistors in series have to have the same current and the voltage has to add up across them while resistors in parallel have to have the same voltage and the current has to add up across them. The same for the voltage divider and current divider formulas -- derive them from the basic concepts.
The better you understand where the formulas you use come from, the less likely you are to miremember them or misuse them.
The Following User Says Thank You to WBahn For This Useful Post:
logearav (01-02-2013)
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
connecting transistors gerases The Projects Forum 69 12-01-2012 12:00 AM
Voltage divider and current divider. Rid_786 Homework Help 2 01-24-2010 06:07 PM
Common Emitter Amp Design hydra504 Homework Help 7 06-30-2009 05:43 AM
LEDs, 555s, Flashers, and Light Chasers (Test) Bill_Marsden General Electronics Chat 13 02-06-2009 07:03 PM
voltage divider pintching off current! need some help... jaydag77 General Electronics Chat 2 05-29-2007 12:07 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
