All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-25-2012, 05:35 AM
wahoomy wahoomy is offline
Default pulsing led
I need to build pulsating LED light,between 6 and 12 volt powersource,but pulse frequency MUST go higher with voltage raise,so if its one blink a second with 6 volts ,it should be like 0.5 sec with 9 volt and so on.i was looking for something like that ,just cant find it on market.thnx ahead for any reply.Btw I`m not a pro in electrics so something more simple would appreciate higher .Thanks
  #2
Old 12-25-2012, 06:57 AM
absf absf is online now
Default
Have not look deep into it but I think it should be possible with some comparators and a VCO like NE566 or 74LS624. But a simple 12F675 with ADC should be able to do it easily. Wait till all the experts are back from X'mas. May be they have simpler solutions.
Allen
  #3
Old 12-25-2012, 05:55 PM
Bernard's Avatar
Bernard Bernard is offline
Default
Might try the VCO section of a CD4046. R1 around 1m, C1 around .1μf, & from bertus, Fmin = 1/ R2 C1; Fmax = 1/ R1C1
Or a 555 with timing R, [ CdS- LED analog photo coupler ], from pin3 to 2&6. Range adjusted with LED current limiting R & LDR series/parallel R.
  #4
Old 12-25-2012, 09:58 PM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
This circuit works in simulation. Frequency vs voltage was as follows:
Code:
6V      .85Hz
7V      2.1Hz
8V      3.5Hz
9V      5.0Hz
10V     6.4hz
11V     7.7Hz
12V     9.0Hz
Select All
The toggle flip-flop on the output is used to maintain 50% duty cycle of the LED, independent of frequency.
The LP2950 is a 5 volt low-dropout regulator, and is available from Jameco and other distributors.
The Following User Says Thank You to Ron H For This Useful Post:
absf (12-25-2012)
  #5
Old 12-26-2012, 06:07 PM
DickCappels DickCappels is offline
Default
RonH,
Elegant!
The Following User Says Thank You to DickCappels For This Useful Post:
Ron H (12-26-2012)
  #6
Old 12-26-2012, 08:54 PM
ErnieM's Avatar
ErnieM ErnieM is offline
Default
I'm on the road with no tools but I did something very similar once,customer required a LED replacement for an incandescent bulb to have very similar brightness when runover 10 to 28VDC range.
Needs: 1 PIC12HV615, 1 resistor for voltage regulator (PIC has onboard current shunt regulator), bypass cap, 2 resistors for A2D ranging, and transistor & resistor for switched (PWM) LED driver. Oh, and the LED.
4 R's, 1 C, 1 Q, 1 IC.
And a little firmware too.
__________________
“Freedom is never more than one generation away from extinction. We didn’t pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children’s children what it was once like in the United States where men were free.”
  #7
Old 12-26-2012, 09:27 PM
Default
I`m impressed with quick ,nomerous response ! Thank you all.I now realize,Ishould have mentioned at first ,I want to install this on my pc, and conect it to PCU cooling fan,so when PCU is loaded,it goes hotter ,automaticlly voltage on PCU fan rises,and voltage rise should accelerate speed of blinking,wich would make the machine look lifelike.However can not power some complicated circuit from PCU cooling fan source. Was hoping for something simple , like resistor/cap, some zenner diode maybe...Anyway thank you ALL for botherin on my trouble.I`ll just keep looking further...
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pls help me.Need advice ridge84 Embedded Systems and Microcontrollers 4 11-29-2009 09:35 PM
Submission, CMOS 555 Long Duration Blue LED Flasher Bill_Marsden Feedback and Suggestions 8 11-08-2009 05:23 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
