All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-07-2007, 10:12 PM
sofakng sofakng is offline
Junior Member
Default What side of this capacitor is negative and which is positive? (picture inside)
Which side of this capacitor is positive and which is negative?
(Click on the image for a few more shots of it)
Here is a link to the Mouser part: http://www.mouser.com/search/Product...985-AFK35V47-F
Thanks for any help!
  #2
Old 11-07-2007, 10:19 PM
jpitz31's Avatar
jpitz31 jpitz31 is offline
Junior Member
Default
When in doubt, look at the data sheet.
There is an image of the cap, with a (-) sign next to the black 1/4 moon mark on the cap.
Joe
__________________
"Resistance is not Futile - Its voltage divided by current"
  #3
Old 11-07-2007, 10:25 PM
Voltboy's Avatar
Voltboy Voltboy is offline
Send a message via MSN to Voltboy
Default
Yeah, the datasheet tells it all. Apart of the black line (which is the negative side), you can see in the "outline drawing" which is the negative terminal.
__________________
Advances are made by answering questions. Discoveries are made by questioning answers.
  #4
Old 11-07-2007, 10:26 PM
cheddy cheddy is offline
Member
Default
Joe
He's right the data sheet does say. Also the black line is the negative on every electrolytic capacitor I've ever seen.
  #5
Old 11-07-2007, 10:33 PM
Junior Member
Default
You guys are awesome, thanks!
Also, a somewhat unrelated question: is super glue condutive? I just used a bunch of it to hold down a socket for a very simple hobby project, but the glue is connecting a couple of pins together...
  #6
Old 11-07-2007, 10:39 PM
jpitz31's Avatar
Junior Member
Default
It is not conductive, but I have used it to hold smd devices down while soldering. When heated the supper glue burns off a bit. But some good PCB cleaner will remove it.
Joe
__________________
  #7
Old 11-07-2007, 11:44 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Safety note: Super glue contains cyanide. Not at all healthy to inhale, especially as fumes while burning off a board. I don't have another suggestion about a glue to use, but super glue is a very bad idea.
  #8
Old 11-08-2007, 12:11 AM
arthur92710 arthur92710 is offline
Default
cyanide will just kill you before you notice the effects of the lead in the solder and the zinc chloride in the solder paste.
  #9
Old 11-08-2007, 01:01 AM
Voltboy's Avatar
Default
You could use hot glue, its very useful. I've used it in many projects.
__________________
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
