All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-07-2007, 02:16 AM
Voltboy's Avatar
Voltboy Voltboy is offline
Send a message via MSN to Voltboy
Default Capacitors blocking DC
Hello.
I was reading about capacitors and I read that capacitors block DC current, but I dont get the point "For circuits with a constant (DC) voltage source and consisting of only resistors and capacitors, the voltage across the capacitor cannot exceed the voltage of the source. Thus, an equilibrium is reached where the voltage across the capacitor is constant and the current through the capacitor is zero"
I really dont get the point of why it block DC current, can someone please explain me what Wikipedia and every other tutorial is trying to say?
I know the question is kinda stupid, dont blame me for not being smart (or for being dumb).
__________________
Advances are made by answering questions. Discoveries are made by questioning answers.
  #2
Old 11-07-2007, 02:27 AM
Salgat Salgat is offline
Default
Applications of capacitors include smoothing out a rectified voltage, or blocking DC and passing AC. The reason why capacitors block DC is because they are simply two separated plates that charge(a gap between them prevents current from passing from one plate to the other). You can think of them as electric sponges. Electricity will be sucked into the two plates but since the plates are separated, once the two plates are fully charged they won't accept anymore current(and thus begin to block any further DC). By putting this electric sponge in parallel with a circuit, any dips and spikes in voltage will result in the capacitor either outputting or absorbing those drops and increases in voltage in order to compensate. The reason why AC passes is due to how capacitors can absorb and give off current to an extent, while in DC the capacitors just absorb until they reach their full capacity and reject any more current.
  #3
Old 11-07-2007, 02:59 AM
cheddy cheddy is offline
Member
Default
On topic, but tangent to the discussion. The other day I tested this out to see for myself. I connected a 470ohm resistor to a 100uf capacitor to a LED around a 9 volt and it was interesting the LED started at full brightness and over the course of a few seconds dimmed to near completely black.
  #4
Old 11-07-2007, 04:40 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
A capacitor is not quite an open circuit. The conductors are close, very close, but they are not closed. So a capacitor can pass AC, if the frequency is high enough, but not DC.
Capacitive reactance is inversely proportional to frequency. So, at zero Hz, capacitive reactance is just about infinite. Same as an open circuit.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #5
Old 11-07-2007, 05:38 AM
chesart1 chesart1 is offline
Send a message via AIM to chesart1 Send a message via MSN to chesart1 Send a message via Yahoo to chesart1
Default
Quote:
Originally Posted by Yoda View Post
Hello.
First and foremost, the question is not dumb and does not cast a negative reflection on you. Perhaps the best way to explain this is via the mathematical formula for the current through a capacitor at any instant in time.
The current through the capacitor at any instant in time is referred to as the instantaneous current.
The instantaneous current through a capacitor is equal to the capacitance in farads times the change in voltage across the capacitor.
Using this formula, it is easy to determine that when the voltage is not changing, the current is zero.
An electric field exists between the plates of a capacitor. I have not seen a good explanation of what happens in the electric field when a voltage is applied across a capacitor.
  #6
Old 11-07-2007, 06:54 PM
nomurphy's Avatar
nomurphy nomurphy is offline
Default
For practical purposes, a capacitor will block DC once it is charged. As the LED experiment above shows, initially the capacitor is a short until it charges to the source voltage.
This is one of the areas where inexperienced engineers make a mistake by not accounting for that initial short, and their circuit can act weird. A good example is audio "pop" when turning on an amplifier or switching between modes such as CD to radio. Although there can be other reasons as well, it is often caused by the charging or discharging of coupling caps within the circuit.
  #7
Old 11-07-2007, 10:22 PM
Voltboy's Avatar
Default
Thanks guys. Now i got the idea.
And cheddy, I did that experiment and saw the effects.
Thanks for helping
__________________
  #8
Old 11-07-2007, 10:43 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
One application for blocking capacitors is coupling the output of one amplifier stage to the next. If you don't use a blocking capacitor a DC offset in the output will affect the biasing of the following stage. Generally speaking it's a bad idea to let this happen. It is quite common, especially, in tube amplifiers to have multiple voltages running around.
__________________
We never have time to do it right,
But we always have time to do it over.
  #9
Old 05-29-2009, 08:46 AM
guitardenver guitardenver is offline
Default
Quote:
Some reason this stuff never works for me. Could you provide a link to a diagram. Is the capacitor in parallel with the light or is it one series circuit?
Is there an experiment I can build easy to help me under stand why you would use a capacitor in a dc circuit? I'm one confused guy.
  #10
Old 05-29-2009, 12:58 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Look at the time date stamp, the original poster is long gone.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
Tags
Related Site Pages
Section Title
Video Lecture Capacitors (Part 2) - Current Flow in a Capacitive Circuit - Inductors,Capacitors,Transformers
Video Lecture Capacitors (Part 1) - Inductors,Capacitors,Transformers
Worksheet Capacitive reactance
Textbook Calculating power factor : Power Factor
Textbook Resonance in series-parallel circuits : Resonance
Textbook AC capacitor circuits : Reactance And Impedance -- Capacitive
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Capacitor transient response : Rc And L/r Time Constants
Textbook Electric fields and capacitance : Capacitors
Similar Threads
Thread Thread Starter Forum Replies Last Post
charging capacitors mach6rick Feedback and Suggestions 1 10-18-2007 10:03 AM
De-coupling capacitors cameo General Electronics Chat 5 07-11-2007 04:28 AM
Capacitors horsebox General Electronics Chat 3 06-17-2007 11:27 PM
Polarized Capacitors for Audio Lines AzifchiK General Electronics Chat 6 06-01-2007 01:29 PM
self charging capacitors brett General Electronics Chat 6 05-27-2007 09:53 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
