All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-13-2012, 09:22 AM
XEB XEB is offline
Post how to calculate 3 phase breaker size with given single phaee load amperes
i want to calculate the size of a 3 phase main breaker of a workshop which has all single phase industrial sockets with total current of 2125 Amp.
40 sockets of 30Amps 40*30=1200
35 sockets of 20 Amps 35*20=700
15 sockets of 15 Amps 15*15=225
=2125Amps
what load distribution should i do?
and what would be the 3 phase main breaker size?
  #2
Old 12-13-2012, 12:10 PM
Dodgydave's Avatar
Dodgydave Dodgydave is online now
Default
Well if your using single phase sockets then you need to be using single phase breakers, as the sockets will have to be evenly distributed across all 3 phases to balance the loads.
Also if you work on the fact that all the sockets wont be used all the time, and work on 75% rule that will be
2125A * 75% is 1600 amps approx over 3 phases gives approx 530 amps per phase THATS A LOT OF POWER !!!
Have you got that?
__________________
NECESSITY IS THE MOTHER OF INVENTION !
  #3
Old 12-13-2012, 12:33 PM
gerty gerty is offline
Default
In most cases that's true!
But he hasn't told us the application yet, if it's some sort of factory most of them may very well be on at the same time.
XEB: you need to give us more information, are these individual circuits going to machines that will be running most of the time?
Or are they going to recepticle circuits in a mall where not much of anything will be plugged in/turned on?
Tags
Related Site Pages
Section Title
Worksheet AC network analysis
Worksheet Superposition theorem
Worksheet AC power
Worksheet Series and parallel AC circuits
Textbook Three-phase Y and Delta configurations : Polyphase Ac Circuits
Textbook Three-phase power systems : Polyphase Ac Circuits
Textbook Single-phase power systems : Polyphase Ac Circuits
Worksheet Voltage divider circuits
Worksheet Overcurrent protection
Textbook Fuses : Physics Of Conductors And Insulators
Similar Threads
Thread Thread Starter Forum Replies Last Post
Transformer configuration to produce 3 phase out of single phase strantor General Electronics Chat 8 09-19-2012 04:52 AM
480 volt single phase lighting Talmadge General Electronics Chat 2 12-21-2008 02:56 AM
Wiring a Single Phase Transformer Bank kittyprincess66 The Projects Forum 16 07-16-2007 05:29 PM
calculation delta and star motor power? straw Homework Help 10 05-15-2007 03:47 PM
split phase power shmerd General Electronics Chat 3 05-21-2005 01:59 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
