Come on. You have been around long enough to know how this works. You need to show some effort at solving the problem and we will help guide you to a solution. The more work you show, the quicker the process proceed.Help with determining logic state of outputs of input clocks
Below picture shows the two questions
Thanks for your help.
I was reading the book...but didnt get it ...Come on. You have been around long enough to know how this works. You need to show some effort at solving the problem and we will help guide you to a solution. The more work you show, the quicker the process proceed.
If the output of the last column is a product of the inputs that go into the first column, and if each column feeds into the next column, then how can you start with the last column?I was reading the book...but didnt get it ...
do we start with the last column...is that in toggle?
Actually, it probably wouldn't be helpful. You text has explained it and your instructor has explained it. So if all we do is work it for you and explain it, then you will not learn this time, either. Instead, you will get credit for work that is not yours and, in the end, become another incompetent engineer who will sooner or later make a mistake that will kill people. So you need to struggle with it and try, which you seem very resistant to, or to fail and go into another field of study where, hopefully, you won't pose a risk to society.if you know it..then it would be helpful to explain how you got to the answer...so I will learn...thanks in advance...
It is not our problem that you put it off to the last minute.eed it by tomorrow...so any one can help that will be great....
in the example we did...we started from the last one...and it was in toggle...so that why i was wonderingIf the output of the last column is a product of the inputs that go into the first column, and if each column feeds into the next column, then how can you start with the last column?
Wouldn't it make a lot more sense to start wi th the column that is directly affected by the inputs.
lol u violated...it was a just a h.w..why making it a big issue bro...Actually, it probably wouldn't be helpful. You text has explained it and your instructor has explained it. So if all we do is work it for you and explain it, then you will not learn this time, either. Instead, you will get credit for work that is not yours and, in the end, become another incompetent engineer who will sooner or later make a mistake that will kill people. So you need to struggle with it and try, which you seem very resistant to, or to fail and go into another field of study where, hopefully, you won't pose a risk to society.
Instead of spending time trying to come up with the next chapter in a sad story about how we should just do your work for you, why don't you spend that time actually trying to do the work your self and posting what you have done and how far you have gotten. Why is that such a hard concept for you to grab onto?
Then post the last one you did and how you solved that and perhaps we can use that as a jumping off point for this one.in the example we did...we started from the last one...and it was in toggle...so that why i was wondering
The scan makes it impossible to read the right hand side.i think this is the one...
the last one is in toggle...so goes like 0,1,0,1,0
The last one is AThe scan makes it impossible to read the right hand side.
What are you calling "the last one"?
nothing is connected to X0 on which end? input or output? which way is the data flowing?we start from X0..nothing is connected to X0...shud it be toggle...
or that example I posted later is not related to this problem
can you see the picture? X0 is the last one...nothing is connected to X0 on which end? input or output? which way is the data flowing?
