All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-04-2007, 05:33 AM
shaam shaam is offline
Default Why voltage amplified
Why voltage is amplified in the series RLC circuit?who is influencing the voltage,probably that is L or C but how & why does it amplify?
  #2
Old 11-04-2007, 06:03 AM
chesart1 chesart1 is offline
Send a message via AIM to chesart1 Send a message via MSN to chesart1 Send a message via Yahoo to chesart1
Default
Energy is stored in a magnetic field in an inductor. The inductor opposes a change in current. The voltage across an inductor is proportional to the rate of change of current. When the current changes, the magnetic field around each loop of the coil changes. While changing, it cuts across the adjacent loop inducing an opposing current. The induced current opposes the changing current.
The formula for the inductor is: the instantaneous voltage across the inductor is equal to the value of the inductor in henries times the rate of change in current. Hence, if a one henry inductor sees a current change of 5 amps in 1 second, a voltage of 5 volts will appear across the inductor.
Energy is stored in an electric field in a capacitor. The formula for a capacitor is.
The instantaneous current through a capacitor is equal to the capacitance in farads times the rate of change of voltage.
The reason for the amplification is that the formulae involve a rate of change and not a magnitude.
  #3
Old 11-04-2007, 09:55 AM
GS3 GS3 is offline
Default
Although technically accurate, I think "amplified" can be misleading because when we talk of an "amplifier" we are referring to a power amplifier. A transformer can "amplify" voltages or currents but we do not call it an "amplifier". There is no "amplification" in an RLC circuit in the common acception of the word.
But, if we accept this use of "amplify" it is not difficult to see why resonance leads to "amplification". The resonant components store and return energy. Just like a pendulum clock. Very small impulses at the escape mechanism result in a rather larger swing of the pendulum.
Tags
Related Site Pages
Section Title
Worksheet Differential transistor amplifiers
Worksheet Multi-stage transistor amplifiers
Worksheet JFET amplifiers
Worksheet BJT amplifier troubleshooting
Worksheet Design Project: Audio power amplifier
Worksheet Class B BJT amplifiers
Worksheet Class A BJT amplifiers
Worksheet Elementary amplifier theory
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
High Voltage, Low Current? jimmy101 General Electronics Chat 3 01-18-2014 11:17 PM
power supply ripple ninjaman General Electronics Chat 11 12-02-2013 04:00 PM
wierd voltage divider issue aruna1 The Projects Forum 16 07-09-2011 03:50 PM
High voltage extremely low currents Ynot1980 Off-Topic 1 12-16-2009 11:32 PM
Treatise about Voltage Ratch Physics 100 05-18-2008 07:55 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
