I have a different application I'm want to try for the MC33033 BLDC motor driver, and would like some input on the logic input.
The driver is expecting input from three Hall sensors to signal the commutation of the motor stator. The original use of the chip is to make a bi-polarity shift to the stator coils also.
What I need is a uni -polar output from the chip, for a switch reluctance motor (SRM).
In the BLDC use the chip is expecting in put from the Hall's as follows -
100 - 110 - 111 - 011 - 001 - 000 A six step commutation of the stator coils results from this.
In the SRM, it only needs a three step commutation -
100 - 110 - 111
My question is, is there going to be a problem with the chip logic only receiving three of the expected signals and repeating? Instead of getting all six signals and repeating.
The data sheet for the MC33033 and page 11 from the data sheet that shows the logic truth tables. The 60 degree logic is the one I would use. Thank you for any input.
100 - 110 - 111
