I need to check out cables with 6 wires in them. Checking the soldering connection will be easy, just measure resistance, but making sure the correct gauge was used is tricky. I cannot open the cable and measure the wire physically, must be done with current or something. Any bright ideas for how this is possible? This is mandatory for our check out at work, the wire gauge is critical for the medical equipment to work properly.
The cable length is 3-5 ft, wires gauges are 18 and 26.
Thanks much!
Thanks much!
