All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-15-2012, 09:33 AM
SNVHKC SNVHKC is offline
Exclamation 555 timer 40khz 50%duty cycle
Could someone help me to generate a 40khz square pulses(Astable multivibrator) using 555timer IC,with 50% duty cycle.
  #2
Old 11-15-2012, 10:50 AM
JDT JDT is offline
Default
This is not the correct forum for this!
A 555 cannot generate 50% duty cycle. Also I'm thinking that a 555 is not the best device for operation at this frequency.
If a 50% duty cycle is important I would have an oscillator that runs at twice the required frequency and follow it with a divide by 2 flip-flop. Easily done in 4000 series CMOS.
Edit: In fact have a look at the datasheet for a HEF4047B. It's all in there!
The Following User Says Thank You to JDT For This Useful Post:
SNVHKC (01-04-2013)
  #3
Old 11-17-2012, 07:01 PM
BillO BillO is offline
Default
Here is link to the data sheet. Page 10 shows one method of doing 50% duty cycle.
You can also google "555 50% duty cycle" and you'll get a few hundred thousand hits.
__________________
Bill
Facts just don't care if you ignore them.
The Following User Says Thank You to BillO For This Useful Post:
SNVHKC (11-19-2012)
  #4
Old 11-19-2012, 03:51 PM
tracecom's Avatar
tracecom tracecom is offline
Default
In the attached schematic, make R1 = 910 Ω, C1 = .001 μF, and R2 = 17545 Ω. (You may use a 15 or 17 kΩ fixed resistor and a series trimpot for R2.) Mathematically, this should produce a 40 kHz output with a 51.26% duty cycle. Of course, component tolerances will cause variation.
The Following User Says Thank You to tracecom For This Useful Post:
SNVHKC (01-04-2013)
  #5
Old 11-19-2012, 07:00 PM
spark8217 spark8217 is offline
Member
Send a message via MSN to spark8217 Send a message via Yahoo to spark8217 Send a message via Skype™ to spark8217
Default
Formula: T = 0.7 * (R1 + (2 * R2)) * C1 (without diode)
f = 1.4 / ((R1 + (2 * R2)) * C1) (without diode)
T = 0.7 * (R1 + R2) * C1 (with diode)
f = 1.4 / ((R1 + R2) * C1) (with diode)
Symbols: T = Time period (Units: Seconds)
f = Frequency (Units: Hertz)
Mark = High time of output waveform (Units: Seconds)
Space = Low time of output waveform (Units: Seconds)
Duty Cycle = % of period T in which output is high (mark)
Data: Mode: Astable
Calculate component values
Frequency = 40 Kilohertz
Duty Cycle = 50 %
Results: Period = 25 Microseconds
Mark = 12,5 Microseconds
Space = 12,5 Microseconds
C1 = 10 Nanofarads
R1 = 1 Kilohms
R1 nearest preferred value = 1 Kilohms (E24 / 5%)
R2 = 1,786 Kilohms
R2 nearest preferred value = 1,8 Kilohms (E24 / 5%)
Diode D1 should not be fitted
The Following User Says Thank You to spark8217 For This Useful Post:
SNVHKC (01-04-2013)
  #6
Old 11-20-2012, 01:09 AM
THE_RB's Avatar
THE_RB THE_RB is offline
Default
Don't use pin7, drive the cap from pin3 which is bipolar (through one resistor), and you just need 1 cap and one resistor and it automatically makes a 50% duty oscillator.
I have not used pin7 in a while, unless I specifically need a 555 with a duty that is NOT 50%.
__________________
Roman Black - PICs and electronics. Author of BTc PIC-sound encoder, Shift1-LCD project, the TalkBotBrain talking PIC controller, LiniStepper open-source microstepping motor driver, the Black Regulator 2-transistor SMPS, and probably some other stuff; www.RomanBlack.com
The Following 2 Users Say Thank You to THE_RB For This Useful Post:
claudewang (11-10-2013), SNVHKC (01-04-2013)
  #7
Old 11-10-2013, 01:41 PM
claudewang claudewang is offline
Default
Hi, there. I have been looking for a way of using ne555 as a 50% duty oscillator with only one resistor tuning for frequency. Your method sounds awesome, but it's still not very clear to me how to implement it. Could you please do me a favor to show me an example circuit that can do exactly what you said? Many thanks.
  #8
Old 11-10-2013, 02:39 PM
MikeML's Avatar
MikeML MikeML is offline
Default
Here is an example of using the 555 to generate a square wave. If doing this at 5V Vcc or lower, use the CMOS version of the 555. Take the output as shown so as not to screw up the timing. Note that V(rc) turns around at 1/3Vcc and 2/3Vcc.
__________________
Mike ML.
I am an engineer and academic. When I talk about current it flows from positive to negative.
The Following User Says Thank You to MikeML For This Useful Post:
  #9
Old 05-02-2014, 11:23 AM
sakar sakar is offline
Default
spark8217 can you please post the circuit diagram relative to which you are providing the values.
  #10
Old 05-02-2014, 11:25 AM
Default
Data: Mode: Astable
Duty Cycle = 50 %
C1 = 10 Nanofarads
R1 = 1 Kilohms
R2 = 1,786 Kilohms
Can you please post the circuit diagram relative to which you are provoding the values.
Tags
Related Site Pages
Section Title
Textbook CMOS 555 LONG DURATION RED LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION MINIMUM PARTS RED LED FLASHER : 555 Timer Circuits
Textbook 555 HYSTERETIC OSCILLATOR : 555 Timer Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help in 555 timer Feedback Circuit The Projects Forum 7 04-01-2012 10:38 PM
Help With 555 Timer Circuit Transistor Swap jimburns The Projects Forum 9 09-29-2011 07:51 PM
555 timer versus PICAXE axeman22 General Electronics Chat 3 07-26-2009 08:59 AM
555 timer - can I do this? tcdk The Projects Forum 2 01-30-2009 07:18 PM
difference between an analog multivabrator and a 555 timer multivbrator anilson General Electronics Chat 2 10-02-2007 02:06 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
