All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-13-2012, 12:48 PM
YeloBlammo YeloBlammo is offline
Default 5 sec delay ON timer
I've searched and searched and haven't come up with an answer.
I'm looking to make a delay ON timer. 5 seconds.
It must behave like so:
The circuit is unpowered. Power is connected. Timer times for 5 sec, then energizes a relay. The relay stays energized until power is disconnected. It resets when the power is reconnected again ( at no given time)
Power is ~28Vdc
Relay coil is 26.5V
Time until relay is energized: 5 sec
The timing portion I have working. I can't get the relay to energize AFTER 5 seconds. It energizes immediately at power on, 5 seconds goes by, then it de-energizes.
My circuit looks like so:
  #2
Old 11-13-2012, 12:51 PM
Default
Like i said, on my breadboard, the relay turns on when power is connected , then off after 5 seconds.
I want it to: turn power on, wait 5 seconds (timing), then the relay energizes. It stays on until power is disconnected.
The relay coil is a 26.5VDC and about 500ohm
  #3
Old 11-13-2012, 02:19 PM
Dodgydave's Avatar
Dodgydave Dodgydave is offline
Default
You need another npn from pin 3 like this...
__________________
NECESSITY IS THE MOTHER OF INVENTION !
The Following User Says Thank You to Dodgydave For This Useful Post:
YeloBlammo (11-13-2012)
  #4
Old 11-13-2012, 08:58 PM
elec_mech elec_mech is offline
Default
To add to what Dodgydave said, your timing circuit is correct, but you need to note how the 555 and NPN transistor are working together.
The 555 outputs a high signal whenever it is timing, effectively on. It outputs a low signal when off or not during a timing cycle. An NPN transistor will be on when the base is high. Hence, when the 555 is timing for five seconds, its output is high and the NPN transistor is on, turning on your relay instead of keeping it off.
To correct this, you can add a PNP transistor as shown below in the top circuit with a couple of resistors. When the timer is on, the NPN is on and 28V is fed to the base of the PNP transistor keeping it off. When the timer turns off, the NPN is off and the PNP base is connected to GND and turns the relay on.
A PNP transistor cannot replace the NPN transistor directly because the base of the PNP must receive close to 28V on its base to turn off the relay. The max voltage of the 555 output will be about 8V, not enough to turn off the PNP transistor controlling 28V to the relay.
Alternately, you can use a second NPN transistor as shown in the bottom-most circuit. When the first NPN is on, the base of the second NPN is tied to GND and effectively off. When the first NPN is off, 28V is fed to the base of the second and the relay will turn on. I'm sure Dodgydave showed this, I just couldn't get the image to open so I thought I'd post one too.
Hope this helps.
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Timer circuits
Worksheet Thyristor application circuits
Worksheet Conventional transistor overview and special transistors
Textbook The Shockley Diode : Thyristors
Textbook CMOS 555 LONG DURATION RED LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION BLUE LED FLASHER : 555 Timer Circuits
Textbook Motor control circuits : Ladder Logic
Textbook Time-delay relays : Electromechanical Relays
Textbook Bipolar junction transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
making a delay off timer sdowney717 General Electronics Chat 12 09-09-2013 01:44 PM
Light dimming using triac and 8051 microcontroller raghurocks The Projects Forum 7 08-16-2012 12:55 PM
Help ....Temperature Sensor Zevoic General Electronics Chat 5 12-31-2011 08:27 PM
10 sec delay on timer lm555 ian.blue The Projects Forum 12 07-18-2011 04:05 AM
LCD and real clock timer apiz88 Programmer's Corner 3 10-03-2008 05:39 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
