Hi chaps ,
I'm in need of help. I am working on a capacitor (home brewed for some old project). It has two metal sheets roughly 50mm by 80mm. I have a NMOS driving a flyback transformer whose output is directed to the plates. Following some calculator on the net, I have an arc of 3-4cm which gives me some 3000 volts(minimum) .
To prevent arcing, I have sealed the positive sheet with carton-sealing tape. It's not even, but with some observation, I was able to seal all sections that are archy/leaky parts.
What I'ld like to know is: at what voltage does this tape breakdown? Based on this knowledge, what is the true breakdown of the teflon-containing paint (I know it's 1000-2000 but a bit sceptical based on the fact that tape isn't as thick as 2 layers of this paint )?
