Center-tapped fullwave rectification without diodes?
Vorador
Joined Oct 5, 2012
87
Hello everyone!
This is a question that has been bothering me for some weeks now. I am having trouble understanding why we need diodes at all for a center-tapped fullwave rectificer circuit. My flawed understanding about electricity is telling me that rectification should be achieved even if I replace the diodes with resistors (forgive me for unashamedly making such a preposterous statement).
I have attached two diagrams - one for the positive cycle of the AC input and the other for the negative one - of what I think should happen in a center-tapped full-wave rectifier circuit consisting of three resistors, an AC source and a transformer.
In the diagram, the resistor in the middle is my output. I have drawn current directions in the diagrams according to my understanding. As you can see, in both the diagrams i.e during one full cycle of the input AC cycle, the current through the middle resistor is invariably unidirectional. But that's obviously not what would actually happen in a real circuit. Resistors can't rectify, but I am speaking on the basis of the circuit geometry alone, which suggests (to me) that the current through that middle resistor must be unidirectional!
I can't see how it is possible for current to reverse its direction through the load in this particular circuit? That's what I need help in understanding.
Please help me realize the silly mistake I am making. It really upsets me when I can't understand some theoretical principle even after giving it much time and thought.
I'd be extremely grateful for your time, patience and response.
Thank you! :)
Audioguru
Joined Dec 20, 2007
11,248
The resistor connected to the center tap has no current through it and no voltage across it because when the voltage on one outer wire goes positive then the voltage on the other wire goes negative with the same voltage then the voltages cancel.
Also when the voltage on the first outer wire goes negative then the voltage on the other outer wire goes positive with the same voltage then the voltages cancel.
Papabravo
Joined Feb 24, 2006
22,084
Resistors conduct current in both directions. Diodes conduct current in one direction only. Why on Earth would you expect them to be the same? Especially for an AC circuit. Probably the same reason people are so easy separate from their money in a financial scam like the Pigeon Drop.
Vorador
Joined Oct 5, 2012
87
I don't expect them to be the same. It's just that analyzing that PARTICULAR circuit made me conclude that they weren't really necessary here.
Thanks Audioguru, it makes more sense now! :)
Vorador
Joined Oct 5, 2012
87
Thanks BillB3857!
So I take it, in the circuit in my first post, the load resistor would get no current at all through it, right?
kubeek
Joined Sep 20, 2005
5,796
Thanks BillB3857!
If the two resistors are the same value, then the load resistor gets no current. If they are not the same value, then the load resistor gets some portion of the AC current that runs through the two "diode" resistors.
BillB3857
Joined Feb 28, 2009
2,573
Everything has a tolerance limit. In addition to what kubeek just posted, there is a tolerance in the voltage from center tap to each end. Any difference there will also produce SOME current through the load resistor.
Vorador
Joined Oct 5, 2012
87
Hmmm. I understand that the two "diode" resistor won't be getting a DC current, but still don't quite grasp how the load resistor is getting AC current.
I think it's because I see the center-tap as ground which only serves as a destination for the current and not as a terminal capable of "forcing" the current away from it at any point during the entire cycle (if you get what I mean).
Surely, this is where I'm wrong?
Thank you so much everyone!
kubeek
Joined Sep 20, 2005
5,796
The center tap is nothing but a connection point in the circuit. It has no special properties compared to the other points. The ground symbol in the circuit is there just so the simulator can do it´s job, you can place it wherever you like and nothing really changes.
Now imagine the CT transformer as two batteries in series, in one half wave with positive polarite and in the other with negative polarity. Also I assume that either the voltage on the transformer is unbalanced or the two "diode" resistors, otherwise there would be no current through the load. See what happens to the voltage across the load and the direction of current through it.
kubeek
Joined Sep 20, 2005
5,796
Also, The circuit makes a resistive divider. When the current through the two "diode" resistors is AC, the current through the load has to be AC as well.
Vorador
Joined Oct 5, 2012
87
Oh wow! I never thought it like that. I always thought of the transformer as being a single polarity-reversing battery with one terminal connected to the top wire and the other to the bottom.
Thank you so very much, kubeek! I appreciate it tremendously! Thanks a heaps!
kubeek
Joined Sep 20, 2005
5,796
Well yes, but with a center tapped transformer you got two of those connected in series and both change polarity at the same time.
