All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-15-2012, 10:30 PM
sdowney717 sdowney717 is offline
Member
Default help me wire up an Omron H3Y-2 delay timer?
PDF describing this device
http://www.ia.omron.com/data_pdf/dat..._4_2_csm92.pdf
Page 9 and 10 show some wire hookups.
I apparently misunderstood how this is supposed to work.
I thought if you connect DC power to pins 13- and 14+, that the relay would click on?? And stay on for xx seconds until the timer went out even if the DC power turns off.
What happens is the PW led lights up and that is all it does.
When the DC power turns off, the led light goes off.
These are new, are they defective?
I have both the timer and the base.
I was looking to use this for 2 small projects on the boat.
First was an electric toilet. I have a momentary on push button that runs head pump, push it is on, let go it is off. How can you use this timer to make it so you push the button and when let it go this timer keeps the power on for xx seconds? Perhaps a switch that is always on and push it goes off?
So then timer would go on with dc power and stay on for xx seconds? And push button again to start cycle over?
See I dont understand how the timer is supposed to function.
Second was the engine oil pressure switch pulsing 12 vdc on and off at idle. I think I cant use this timer like I thought.
  #2
Old 10-15-2012, 11:15 PM
JMW JMW is offline
Member
Default
It has been a decade or so since I've used these, but here goes. The power voltage must be on for the duration of the cycle. Once power is applied, the timer circuit will operate. So is what you need to do is apply power to a timer relay, the contacts of this relay will supply power to operate the timer relay. Example ground pin 14. Tie pin to 4 to pin 13. Tie pin 12 to 12 VDC. Apply your momentary switch to pin 13. The relay closes for period "x" This period will should be of sufficient length to "flush the head". Contacts 9 and 5 operate the flush cycle. Hopefully they are rated sufficiently to operate the head, otherwise an additional relay will be needed.
As for your engine alarm. I recommend you use a relay to open the low oil sender when the tach reads below 1000 RPM or what ever level you determine. Many tachs run off the alternator, should be relatively simple to build a 555 timer circuit to do just that. As you owe me big time for the timer advice, how 'bout designing the circuit, I'm currently working on a boat and this will be a great idea. Just kidding on the last, but I'll bounce it off the owner and see if he wants me to add it to is list. I think we came up with something.
  #3
Old 10-16-2012, 12:04 AM
Member
Default
Hi, thanks for responding
Your saying
The pin 14 has a + sign, does this matter?
Ok thinking of what your saying. Pin 12 gets 12vdc+
pin 4 to pin 13
Now my momentary switch how does this connect into pin 13?
please clear this up
  #4
Old 10-16-2012, 01:07 AM
Member
Default
Ok, I played around with these, they are not very good. One is broken.
Dial indicator for seconds is very rough meaning set for 10 seconds it is 7 seconds, etc...
They are DELAY timers.
Apply 12vdc power to 13 and 14 observing polarity
What happens is the power LED will light up.
Then after ax xx delay, depending on where the dial is set, the relay will activate. Once activated the relay is engaged, both LED are lit, and the timer will use power continually.
The one that is broken always comes on with no delay. Although for a few tries it functioned normally.
So are they about worthless for my apps? Wasted money on them. Garbage, IMO.
What I really want is a timer that runs for xx seconds then shuts off the relay. Anyone have a link?
Use for toilet, means relay will always be sucking power?
Thinking about it, I would need a different type momentary switch. One that is always on, then push it in goes off.
Pushing in button will reset the relay, toilet runs xx seconds. Then relay activates opening circuit. Relay stays energized. till you push button again.
Bad thing about this is if you loose power to the circuit, then when you restore power, toilet will always run xx seconds, then relay will stay activated using up battery power, which could drain the batteries. On a boat you dont want to needlessly use up power.
Another bad thing is say relay fails, which it likely will seeing quality and on a boat. Then toilet motor just runs forever!
Real bad seeing the toilet cost $499. And it could even overheat and start a fire.
  #5
Old 10-16-2012, 04:19 PM
JMW JMW is offline
Member
Default
These are exactly what you want. Sorry about the polarity, follow the spec sheet.
Your momentary switch provides power (12 Volts) to start the relay, once it is started, one set of N.O. contacts supplies power to keep the relay "latched" for the time needed (7 seconds). The other set of N.O. contacts provides power to the head. The time must be accurate as you can waste a fair amount of water in 3 seconds.
  #6
Old 10-16-2012, 04:47 PM
Member
Default
I found something better with this setup.
http://forum.allaboutcircuits.com/sh...ad.php?t=75748
Regarding The Omron, I got a refund on one of them from Ebay seller in China.
I tested and found out one was defective as in always on with no delay, other one works. those Omrons were ~$5 each but still dont like wasting money or time as it gets discouraging.
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Electromechanical relay logic
Worksheet AC motor control circuits
Textbook The S-R latch : Multivibrators
Textbook Programmable logic controllers : Ladder Logic
Textbook Motor control circuits : Ladder Logic
Textbook Time-delay relays : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do I make a specific MCU pin HIGH for 1hr. poxkix Embedded Systems and Microcontrollers 35 01-06-2012 04:31 AM
Time delay in buzzer beeps using 555 timer Xufyan General Electronics Chat 10 04-30-2011 07:59 AM
designing a combination of delay timer and relay abhishek_mitra The Projects Forum 12 10-13-2009 06:59 PM
Two stage timer. Need advice. Airasolt The Projects Forum 2 09-10-2009 12:15 PM
LCD and real clock timer apiz88 Programmer's Corner 3 10-03-2008 05:39 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
