| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
Hello everyone! I'm new to this so please bear with me. I have a battery charger connected in my RV to maintain the batteries. Problem is: If I try to use the 12v radio, I get a hum if the charger is on. Sounds like 60 cycle, but I'm not sure. There is a .22v AC component with the charger on the low (3A) setting, ~.5v AC at the 10 amp setting. Is there a way to filter this, or should I just buy one of the new "smart chargers"? I've looked at the Rectifier/Filter circuit in the Volume VI experiments. Will this work? Any help would be appreciated!
#2
I would definitely try filtering the power supply as a first measure. A good sized choke and a couple capacitors should be a good starting point.
In the end though it could be that some or most of the hum is coming in the antenna and that would require other measure. To test this you can power the radio momentarily from a separate battery which is not being charged and see if the noise disappears. |
#3
Besides an L-C AC ripple filter, make sure you have a good battery or batteries & the connections are clean & tight; the battery provides some filtering itself. One way to check the battery operation & connections is to unplug the charger with some lights on; if they immediately dim then the battery isn't doing its job, either because of poor connection[s] or it's nearly dead & won't charge.
__________________
Dave If it ain't broke, learn how it works & improve it. |
#4
Quote:
#5
Try a filter on the radio itself. Filtering 100% of the current used by the RV is not needed (and not easy). Only the current drawn by the radio need be filtered.
Get a pair of electrolytic capacitors and a small "step-down" transformer from a surplus electronics dealer. Cover the transformer secondary leads with wire-nuts or heat-shrink, so that they will never make electrical connection with anything. Hook each transformer primary lead to the "+" terminal of each of the capacitors. Hook the "-" leads of the capacitors to each other, and to the "-" of your 12V power cord. Hook "+" of power cord coming in to one of the "+" terminals of the capacitor. Hook "+" of power cord out to radio to the other capacitor's "+" terminal. This should greatly reduce the hum. To learn how this circuit works, run a Google search on the exact phrase: "pi filter."
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me" - Michael Faraday |
#6
Quote:
#7
Quote:
| Tags |
| battery, charger, hum |
Related Site Pages
| Section | Title | |||
| Worksheet | Basic AC-DC power supplies | |||
| Worksheet | Design Project: Sensitive audio detector | |||
| Worksheet | Advanced electromagnetism and electromagnetic induction | |||
| Worksheet | Passive filter circuits | |||
| Worksheet | Basic oscilloscope operation | |||
| Worksheet | Batteries | |||
| Textbook | Low-pass filters : Filters | |||
| Textbook | Vacuum tube audio amplifier : Discrete Semiconductor Circuits | |||
| Textbook | Rectifier/filter circuit : Discrete Semiconductor Circuits | |||
| Textbook | Diode switching circuits : Diodes And Rectifiers | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 48V Lead acid battery charger circuit | nhh | The Projects Forum | 26 | 12-22-2009 07:17 PM |
| Project: Battery charger regulator | beenthere | The Completed Projects Collection | 21 | 10-10-2009 03:08 PM |
| 12v lead acid battery charger circuit | ruleworld | General Electronics Chat | 2 | 09-07-2007 09:40 AM |
| ALKALINE BATTERY CHARGER | lildiesel6075 | The Projects Forum | 32 | 06-22-2007 12:51 AM |
| Hooking up 2 car battery chargers to 1 battery, in parallel | gazzonyx | The Projects Forum | 7 | 03-10-2007 05:09 AM |
| Thread Tools | |
| Display Modes | |
