Hello, all
I am given the following circuit
The problem states: \(D_1\) and \(D_2\) have different cross sectional areas but othewise identical
(1) Find the current following through the diodes.
(2) If \(I_{in}=8mA\) and \(D_2\) has 2 times the larger cross sectional area than \(D_1\). Calculate current following through each diode
No values for the components are given.
My complications: I am on part one.
I am sure as what diode model to use. If I use ideal diode model then the diodes would be forward biased and would essentially act as a short circuit thus, shorting out the other diode. Correct?
Or I could use the constant voltage drop model with \(V_D=0.7V\)
and do KVL for both loops but that doesn't workout either. Likewise, I could use the battery plus model and solve for some general equation for the currents through each diode but it doesn't seem to make much sense.
I, also, know that for the exponential model for a diode that the saturation current of the diode (\(I_s\)) is proportional to the junction area of the diode. So I know at least for part two that diode \(D_2\) should exhibit a large current.
In, short how would I go about this problem
