All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-12-2012, 06:39 PM
parklol parklol is offline
Junior Member
Default 12VAC to 12VDC Converter
Hi, I am trying to design a 12VAC to 12VDC converter. The simplified circuit is attached below.The problem is that I have to use SMD component. The capacitor I can only find is 16V 220uF, and it is not safe to just put the capacitor right after the rectifier. Are there any way to solve this problem? -Leo
  #2
Old 10-12-2012, 07:07 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
The peak voltage of a sinus is sqr(2) * the input voltage , the voltage drop over the diodes is about 0.7 Volts
So the output voltage will be around 12 * 1.414 - 2 * 0.7 = 15.6 Volts
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 10-12-2012, 07:28 PM
mcgyvr mcgyvr is offline
Default
What Bertus said is obviously correct..
I would just use the bridge.. and a LM7812 12V regulator or similar with the required input/output caps as per the datasheet.
You didn't specify a current requirement though..
  #4
Old 10-12-2012, 07:33 PM
chrissyp chrissyp is offline
Member
Default
If the current is low a zener diode could be used to pull the voltage back down to 12vdc
  #5
Old 10-13-2012, 02:59 AM
MrChips's Avatar
MrChips MrChips is offline
Super Moderator
Default
Quote:
Why do you say "it is not safe to just put the capacitor right after the rectifier"?
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
  #6
Old 10-13-2012, 06:00 AM
ScottWang ScottWang is offline
Default
I' afraid the Cap value is not enough, you may use 4 pieces of 220uf/16V, each two capacitors series and then parallel, the cap will become 440uf/32V.
  #7
Old 10-16-2012, 07:23 PM
Junior Member
Default
Quote:
The capacitor I found is 16V, but the peak voltage of 12VAC is about 17V. Even there is some voltage drop through the rectifier, it is still not safe to put the capacitor right after the rectifier.
  #8
Old 10-16-2012, 07:27 PM
takao21203's Avatar
takao21203 takao21203 is offline
Send a message via Skype™ to takao21203
Default
Use a 25V capacitor. They are as readily available (in SMD) as 16V caps.
If you load the circuit with current, voltage will drop anyway.
It takes about 20 or 22V to blow up a 16V eletrolytic cap. At least.
  #9
Old 10-16-2012, 07:36 PM
Junior Member
Default
Quote:
Originally Posted by bertus View Post
Bertus
Yes, you are right. this seems work based on the calculation. The power supply I am using is a 120VAC to 12VAC transformer. However, the line voltage varies, so sometimes the output of transformer will give like 12.7VAC.
I can add another diode to reduce more voltage or add a regulator in between. The maximum current I need is 1.5A, adding these components will produce too much heat.
Are there any other solutions?
  #10
Old 10-16-2012, 07:43 PM
MrChips's Avatar
Super Moderator
Default
All linear voltage regulators have to give up excess power as heat.
You have to switch to a switching regulator if you want to be cool.
__________________
Tags
Related Site Pages
Section Title
Textbook Zener diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
12vac to 12vdc jerrymyersmills The Projects Forum 2 05-27-2011 04:38 AM
12vdc vs. 12vac Lightfire General Electronics Chat 5 05-07-2011 02:40 PM
Buck converter and Boost converter porky67 General Electronics Chat 12 12-09-2010 04:39 AM
12VAC common to 12VDC floating Kelly Lee The Projects Forum 2 08-25-2009 04:31 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
