All About Circuits Forum
Go Back   All About Circuits Forum > All About Circuits Commmunity Forums > Feedback and Suggestions
Notices
Feedback and Suggestions Forum for providing feedback and suggestions about All About Circuits, including corrections to the e-book. This forum is not for getting help with technical questions.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 01-05-2005, 12:28 AM
SiegeX SiegeX is offline
Junior Member
Default
In the Fuses Chapter in the DC Volume there is the following sentence
Quote:
Neither fuses nor circuit breakers were not designed to open in the event of a person getting shocked
This sentence has a double negative and thus reverses the meaning of what I beilieve the author intended it to say. I believe the correct saying would be
Quote:
Neither fuses nor circuit breakers were designed to open in the event of a person getting shocked
All I did was remove the word "not" highlighted in bold above.
  #2
Old 01-10-2005, 10:29 PM
Junior Member
Default
In the "Factors Affecting Capacitance" chapter in the DC Volume there is the following sentence that I believe is a bit too vauge and abstract
Quote:
PLATE AREA: All other factors being equal, greater plate gives greater capacitance; less plate gives less capacitance.
I think it would read much better the following way, changes highlighted in bold.
Quote:
PLATE AREA: All other factors being equal, greater plate area gives greater capacitance; less plate area gives less capacitance.
  #3
Old 01-10-2005, 10:37 PM
Junior Member
Default
I found another tiny typo, thought I would just post it here rather than starting a new thread.
In the "Practical Considerations" for Capacitors chapter the following sentence has a typo marked in bold
Quote:
Polarity: Some capacitors are manufactured so they can only tolerate applied voltage in one polarity but not the other. This is due to their construction: the dielectric is a microscopically thin layer if insulation deposited on one of the plates by a DC voltage during manufacture.
In cased you missed it, the if should be replaced by an of
  #4
Old 01-12-2005, 08:58 AM
Junior Member
Default
Another typo in the Inductor Chapter under "Practical Considerations". Typo highlighted in bold
Quote:
Equivalent circuit: Since inductor wire has some resistance, and circuit design constraints typically demand the inductor be built to the smallest possible dimensions, there is not such thing as a "perfect" inductor
Not should be replaced with no
  #5
Old 01-12-2005, 09:16 AM
Junior Member
Default
All About Circuits > Volume I - DC > Chapter 16: RC AND L/R TIME CONSTANTS > Voltage and current calculations
Quote:
The rise and fall of circuit values such as voltage in current in response to a transient is, as was mentioned before, asymptotic.
in should be and
  #6
Old 01-13-2005, 08:29 PM
imported_jrap imported_jrap is offline
Junior Member
Send a message via Yahoo to imported_jrap
Default
Hi SiegeX!
Thanks so much for pointing out these mistakes. I'm going to let Dennis or Tony approve them first before I fix them here, as they are maintaining the book.
Thanks again
  #7
Old 01-16-2005, 09:56 AM
Junior Member
Default
Im glad to be of help, it's the least I can do for such a great free resource. Have said that, here are two more I found in the same chapter:
All About Circuits > Volume II - AC > Chapter 3: REACTANCE AND IMPEDANCE -- INDUCTIVE > Series resistor-inductor circuits
Quote:
If we were to restrict ourselves to the use of only one form of notation, the best choice would be polar, because it is the only one that can be directly correlated to real measurements.
Change added in bold
Quote:
Across voltage across the resistor is in phase (0o shift) with the current through it; and the voltage across the inductor is +90o out of phase with the current going through it. We can verify this mathematically:
Extra "Across" needs to be removed.
  #8
Old 01-16-2005, 10:17 AM
Junior Member
Default
All About Circuits > Volume II - AC > Chapter 3: REACTANCE AND IMPEDANCE -- INDUCTIVE > More on the "skin effect"
Quote:
This is simply an estimated figure of pure resistance for the conductor (that opposition to the AC flow of electrons which does dissipate power in the form of heat), corrected for the skin effect.
I think it reads better with "the" added.
  #9
Old 01-18-2005, 08:30 PM
Junior Member
Default
All About Circuits > Volume II - AC > Chapter 4: REACTANCE AND IMPEDANCE -- CAPACITIVE > AC capacitor circuits
Quote:
However, we need to keep in mind that voltage and current are not in phase here. As was shown earlier, the current has a phase shift of +90o with respect to the voltage. If we represent these phase angles of voltage and current mathematically, we can calculate the phase angle of the inductor's reactive opposition to current.
As you can see from the chapter heading, "inductor's" should be replaced with "capacitor's"
  #10
Old 01-19-2005, 11:46 PM
Junior Member
Default
All About Circuits > Volume II - AC > Chapter 5: REACTANCE AND IMPEDANCE -- R, L, AND C > Parallel R, L, and C
The following picture has an error, you will notice that you have "Vic" listed twice, once above the capacitor and once above the resistor. The one above the resistor should be labled Vir as per the spice file dictates.
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
pHEMT small signal simulation using ADS ruby.n The Projects Forum 6 07-20-2009 02:28 PM
What is the difference between small signal and large signal?? Ehsan Ullah General Electronics Chat 2 08-31-2008 03:01 PM
Power Factor Correction 2rlp General Electronics Chat 13 07-19-2008 07:02 PM
Possible Grammar Correction Needed Professor Thom Feedback and Suggestions 10 06-08-2008 11:51 AM
Correction needed - Please cumesoftware Off-Topic 17 10-16-2007 12:56 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
